04-26-2021, 10:54 AM | #1 |
Torque spec for spark plugs?
I am likely being waaaay too anal, but is there a torque spec for the spark plugs on the original head? In the back of my mind I recall seeing one but can't find it in any of the references I have on hand.
Otherwise, snug plus a scoch will have to do. JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
04-26-2021, 11:15 AM | #2 |
Re: Torque spec for spark plugs?
Use original wrench,as tight as you can get with one hand
04-26-2021, 11:46 AM | #3 |
I like such workable technical terms ! |
04-26-2021, 04:56 PM | #4 |
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Seems like I recall seeing....and using......one for about 15 ft/lb recently.
04-26-2021, 06:03 PM | #5 |
I think an original wrench, tightening by hand, would be more than 15ft/#, especially back in the day when men were stronger, and didn't want a plug shoot through the hood out in nowhere land!
04-26-2021, 06:43 PM | #6 |
04-26-2021, 07:36 PM | #7 |
I had just posted this to a thread about manifold torque... same applies here.
"good and tight" is about right !! I suspect that about 99.9% of all Model A's lived their first 50 -60 years without ever encountering a torque wrench. Joe B |
04-27-2021, 12:54 AM | #8 |
The length of the original wrench would get you more like 45-50 FPs if you pulled them real tight. They don't need to be that tight. Just snugged down so they don't leak past the sealing washers.
04-27-2021, 10:37 AM | #9 |
Thanks, all. I've spent a lot of time working on BMW motorcycles where engine and tranny parts are either aluminum or magnesium, and torqueing to spec is pretty critical. I'm as interested in consistency as I am in the value. I'll mess around and see what feels right and develop a spec from that, I suspect it's going to be in the 20-25 ft-lb range (about half of the head nut spec of 55 ft-lb).
JayJay
04-27-2021, 11:25 AM | #10 |
I'm with you this. Go beyond that and you will have a problem getting them loose, especially on aluminum heads.
04-27-2021, 12:35 PM | #11 |
A little anti seize on the threads will help with consistent tightening and help when it comes time to remove the plugs, especially with aluminum heads.
04-27-2021, 04:39 PM | #12 |
Head types that is: C. I. vs Aluminum and thread size matters see tables here.
Following info is from this URL: https://ricksfreeautorepairadvice.co...k-plug-torque/ Last edited by Benson; 04-27-2021 at 04:46 PM. |
04-27-2021, 04:51 PM | #13 | |
JayJay
04-27-2021, 07:49 PM | #14 | |
Tight is tight too tight is broke?? Sent from my iPhone using Tapatalk |
