Old 04-11-2017, 02:24 PM   #1
ford33
Default Help with identifing Crown and pinion
The gear set on the left side is a 4.11 for a 1932-1934 diff. Can anyone help with the identity of the set on the right. It is also a 4.11. The crown gear is thicker and the pinion gear is bigger. The pinion shaft is also fatter (2") and longer (7 7/8") Both sets are Ford script
ford33 is offline   Reply With Quote
Old 04-11-2017, 03:23 PM   #2
svm99
Default Re: Help with identifing Crown and pinion
'35 to '38 V8 it appears.
svm99 is offline   Reply With Quote
Old 04-11-2017, 06:07 PM   #3
rotorwrench
rotorwrench's Avatar
Yup, Those were the 10-spline years. The 6-spline took over after that. The carrier bearing size was different between the 35/36 rear axle and the 37/38 but there was no difference in the crown wheel.
Old 04-12-2017, 12:19 PM   #4
ford33
Thanks for the help
