Old 07-14-2021, 10:23 AM   #1
alumcantandthd
Default Steering box grease?
HI, have a question reguarding all you steering box lubricant gurus.
John Deere Cornhead grease seems to be the 'go-to' lubricant you guys (including later 1930's) use in yer steering boxes.
What are your opinions on, Cotton Picker Spindle Grease 00? (Tractor Supply has it) It was highly recommended to me over the Cornhead grease.
Also opinions, on mixing (blue) STP in with the steering box lubricant?
Thank.
alumcantandthd is offline   Reply With Quote
Old 07-14-2021, 10:55 AM   #2
JKY
Default Re: Steering box grease?
We don't use grease. Opened a couple that had been greased and it was all caked around the casing and nothing was on the actual gears. Cornhead may be different. Don't use it. We use 600W which we make with about 50/50 145W gear oil and STP blue.
JKY is offline   Reply With Quote
Old 07-14-2021, 11:32 AM   #3
alexiskai
alexiskai's Avatar
I would read through this thread, it's the most recent full discussion on this topic.
https://www.fordbarn.com/forum/showt...n+00&showall=1
Old 07-14-2021, 07:59 PM   #4
alumcantandthd
Thanks!
Old 07-15-2021, 01:14 AM   #5
Randy in ca
Randy in ca's Avatar
Why would you tell someone not to use something that it would seem you know nothing about?
Randy in ca is offline   Reply With Quote
Old 07-15-2021, 07:05 AM   #6
alexiskai
alexiskai's Avatar
I'll add that I did buy a bottle of the Champion 00 grease that Brent recommended and I put it in my 7-tooth steering box. The first time I put it all back together, I did the steering cover gasket wrong and it leaked a lot. So I took it apart, and I observed that the Champion 00 did an excellent job clinging to the gears, even after a lot of it had leaked out. I repaired the gasket and refilled the box and it hasn't leaked since.
Old 07-15-2021, 07:31 AM   #7
WHN
Thank.
I personally like the John Deere Cornhead grease and see no reason to change. I do think your other two mentioned options would work but why change?
This is one of those minor things, that we spend to much time on.
Enjoy.
Old 07-15-2021, 08:33 AM   #8
alexiskai
alexiskai's Avatar
I have a theory that the reason we spend so much time on it is that, unlike the motor oil or transmission or rear end, it's a PITA to change the steering box fluid and also a pain to re-do the seals if it leaks, so people stress about doing it right the first time.
Old 07-15-2021, 08:35 AM   #9
alumcantandthd
I'm 'not' changing lubricants, or a 'brand name' of lubricant. I have newly rebuilt steering box and was addressing what would be today's better lubricant to put in it.
'Today's' worst lubricant made, is way better than 'yesterday's' best lubricant.
I was told that the 'molasses' viscosity of the Cotton Picker Spindle Grease 00 would be better in lubricating low speed gears, than the thicker Cornhead grease. Also to mix a little STP in with the Cotton Picker.
In all of the forums I have been reading, there is no mention of the Cotton Picker brand of lubricant. So I asked on this site, since you guys have figgured out which is the better/best steering box lube.
Thanks
Old 07-15-2021, 12:32 PM   #10
California Travieso
Send a message via Yahoo to California Travieso
Randy,
Sound to me like a regional dialect. I think what he meant was: “(we) don't use it.” He did go on to say “We use 600W . . .”
David Serrano
California Travieso is offline   Reply With Quote
Old 07-15-2021, 07:11 PM   #11
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Any lubricant recommendation for those using the early 1950's Ford F100 steering gear?
fried okra is offline   Reply With Quote
Old 07-19-2021, 12:41 PM   #12
rfequity
What is STP Blue?
rfequity is offline   Reply With Quote
Old 07-19-2021, 01:46 PM   #13
1931 flamingo
1931 flamingo's Avatar
Penn Rite steering box lube...................NO leaks. FWIW
Paul in CT
Old 07-19-2021, 02:37 PM   #14
WHN
Originally Posted by rfequity View Post
What is STP Blue?
Engine oil additive. Protects against engine wear. Increases viscosity of oil.
Could help a high mileage engine.
Enjoy.
Old 07-19-2021, 04:28 PM   #15
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Randy, if you think this sort of thing can be bad here, ...you should read some of the inaccurate advice coming off of the social media Model-A pages. It has been said that about 80% of the information you read on those social media sites is incorrect, ...and I have found that to be very true. People will make-up whatever seems believable just to get to post something.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-19-2021, 05:28 PM   #16
SeaSlugs
SeaSlugs's Avatar
What is STP Blue?
Found nearly anywhere engine oil is sold, says STP OilTreatment. Usually about $4 or so. Makes oil extra clingy.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-19-2021, 05:35 PM   #17
jayvee34
jayvee34's Avatar
I have one in my "A", Randy Gross, the builder of my F100 box said 600W or
the 85W/140 was ok. (used 600W that I had on hand, no leaks).
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 07-20-2021, 05:21 AM   #18
oldredford
I use 600 weight. Or 80-140 lube.
oldredford is offline   Reply With Quote
