Old 11-22-2020, 03:52 PM   #1
Ronnieroadster
Ronnieroadster's Avatar
Default Aluminum cam gear with additional holes to advance or retard cam position
City: Wallingford
State: CT
Price: 80.00
Here's an nice used aluminum cam gear stamper B&D that besides the stock bolt holes also has additional bolt holes to allow advancing or retarding the cam position from the stock location. The gear teeth pitch angle is the early style used from 1932 to 1948 this allows the cam to thrust towards the block. The center hole has been opened up so it can also be used on the later style cam allowing clearance for the distributer drive gear. The amount of degrees changed by using the additional advance or retard location is unknown.
The price is $80.00 this includes shipping in the USA
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
