Old 11-22-2020, 02:31 PM   #1
MyTwOfOrDs
Default 6v gen
I'm not putting out enough to put decent charge into battery. I'm told regulator can be upped
MyTwOfOrDs is offline   Reply With Quote
Old 11-22-2020, 02:38 PM   #2
Will D
Will D's Avatar
Default Re: 6v gen
Is it a 3 or 2 brush generator? If 3, the third brush can be adjusted to increase or decrease output.
Will D is offline   Reply With Quote
Old 11-22-2020, 03:35 PM   #3
MyTwOfOrDs
Default Re: 6v gen
no Doug cant be that lucky. however I think the old boy did brushes, Too much meat for 84 yrs. however still like to turn out a good 1/2 more volt
Old 11-22-2020, 04:43 PM   #4
JSeery
JSeery's Avatar
Default Re: 6v gen
Can you measure the output? Should be above 6v for sure, somewhere in the 7.2/7.3v range
Old 11-22-2020, 05:46 PM   #5
MyTwOfOrDs
Default Re: 6v gen
6.2 to 6.3 max. this regulator spring bending to increase has me
Old 11-22-2020, 05:47 PM   #6
MyTwOfOrDs
Default Re: 6v gen
did the field to ground, and zip all
Old 11-22-2020, 07:10 PM   #7
JSeery
JSeery's Avatar
Default Re: 6v gen
Voltage regulators can be adjusted, BUT, it requires bending components and a very small adjustment can make a big difference.
Old 11-22-2020, 08:14 PM   #8
MyTwOfOrDs
Default Re: 6v gen
so whats best way to test gen?
Old 11-22-2020, 08:48 PM   #9
fordwife
Default Re: 6v gen
I assume we are talking about a Ford. Get a good repair manual that covers the electrical system and follow the test procedure or find someone who is familiar with Ford systems. I for one would not try to tell you what to do online, except make sure reg is grounded and all connections are clean and tight. Maybe someone else will chime in.
fordwife is offline   Reply With Quote
