Old 11-19-2020, 09:42 AM   #1
WRA
WRA's Avatar
Default 1932 Ford Pedal Pads Question
I’m working on getting my 32 Back on the road and I’m missing the pedal pads. The pedals are stock 32 and are not threaded.
What pads can I use, or am I restricted to 32 Only.
Thanks
WRA is offline   Reply With Quote
Old 11-19-2020, 10:14 AM   #2
Tim Ayers
Default Re: 1932 Ford Pedal Pads Question
Thanks
I think so and Bob Drake offers repops of them. DavidG will be the expert on this question.
Old 11-19-2020, 10:22 AM   #3
Automotive Stud
Automotive Stud's Avatar
You need the '32 pedal pads that the pad has a stud and nut. They are available reproduction. The later pedal pads have a larger stud and thread right into the pedals. You could use those but you'd have to tap threads in your pedals.
Automotive Stud is offline   Reply With Quote
Old 11-19-2020, 10:32 AM   #4
Tim Ayers
The rubber surface was bonded to the medal pad. Another option it to source a used set and put a set of pad covers over the OEM ones.
I don't have the pedals in front of me, but I seem to recall that '33-'34 pedals are also bolt on.
Old 11-19-2020, 02:09 PM   #5
hop up
hop up's Avatar
The 1933 1934 pedals are threaded
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 11-20-2020, 11:40 AM   #6
32phil
Ford also made cast iron ( I think or perhaps bronze ) pedal pads.
They look identical to the bonded rubber units just all metal no rubber.
They were on big trucks and are rare and desirable I believe.
They're pretty neat looking
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 11-20-2020, 04:42 PM   #7
DavidG
DavidG's Avatar
hop up,
Early '33s used the carryover '32 pads and the pedal ends were formed like the ends on the '32 pedals. They weren't threaded and the pads were attached with thin check nuts and lock washers as with the '32s.
32phil,
With respect, those cast iron pedals were WWII service parts when rubber was embargoed; they weren't used in '32 production.
Old 11-20-2020, 07:05 PM   #8
Fortunateson
There is a fellow on the HAMB that is repopping them I believe. I think he is in Kamloops BC.
Fortunateson is offline   Reply With Quote
Old 11-21-2020, 08:48 AM   #9
hop up
hop up's Avatar
Thank you for the info DavidG always learning on the fordbarn . I have always wondered about the metal petal pads and thought they were commercial. I have one and would like to find another,as they give extra room for a size 14 shoe.
Old 11-21-2020, 05:43 PM   #10
DavidG
DavidG's Avatar
Michael Driskell (Third Gen Automotive) may have one.
Old 11-22-2020, 09:23 AM   #11
32phil
Thanks Dave
I always thought they were heavy duty truck units.
Now I know they are WWII..........
... makes me want a pair even more !
