03-24-2020, 03:13 PM | #1 |
59a Main bearings replacements
So now sourcing parts for 59A engine rebuild.
Main Bearings: 81A-63305-030 for 2.499" journal 39- 48 1BA-63305-030 for 2.499" journal. 49-53. Are these bearings the same or are they different? Thanks Phil NZ |
03-24-2020, 03:16 PM | #2 |
Re: 59a Main bearings replacements
Mainbearings must be for the type of block you use...older has a wider locking tab...-49 up has a smaller.
03-24-2020, 03:21 PM | #3 |
03-24-2020, 03:25 PM | #4 |
Yeah you need the earlier type. the locking tab width is an easy indicator. The width of the web of the block at the rear main is different too. I learnt this the hard way when I assumed a French motor would use 8BA bearings. They dont. They use 59A type.
03-24-2020, 03:28 PM | #5 |
You´re a bit to far away...Still have a few sets on the shelf.
03-24-2020, 03:43 PM | #6 | |
Expect parts now ordered from overseas will be moving at a slower rate. My crankshaft and block now in lock down for next 4 weeks. Phil NZ |
03-24-2020, 03:46 PM | #7 |
MEMBER EMERITUS
As far as the postal service is concerned there wouldn't be too much difference in shipping from either Sweden or the USA to NZ.
03-24-2020, 03:59 PM | #8 |
Probably cheaper from Sweden. I find USA postal charges to be the most expensive of anywhere in the world.
03-24-2020, 04:00 PM | #9 |
Shipping still works atleast...i crated a flathead boatmotor going to south germany today.
A day slower or 2 is fine...just as long as it doesn´t stop completely... |
03-24-2020, 07:52 PM | #10 |
Bra!
[if I got that correct]
"Came too close to dying to stop living now!" |
03-25-2020, 10:00 PM | #11 |
Have you tried ajays and west coast ford?
03-26-2020, 03:30 PM | #12 |
The numbers that are the same identify the parts as main bearings.
The first number tells you what specific car or engine they fit. |
03-26-2020, 06:11 PM | #13 |
I'm pretty much sorted now with the bearings thanks to Flatheadmurre.
Much appreciated. Phil NZ |
03-27-2020, 05:26 PM | #14 |
The only engine you have to watch out for in those years in the Canadian sourced 69A. It has some different bearings associated with it. The 59A is no problem.
04-04-2020, 05:47 PM | #15 |
FlatheadMurre,
Am keen to sort out the purchase of bearings. Have sent you messages. So will try here. Thanks, Phil NZ |
