Old 11-14-2017, 10:33 PM   #21
GB SISSON
GB SISSON's Avatar
Default Re: SO incredibly mad at myself!!!
Originally Posted by deuce_roadster View Post
If you used the switch to shut off the engine, how did it get back to the ON position? Did I miss that?
The engine was never running. It was just switched on to mess with the gauge and if it was functioning or not. In a daily or weekly driving situation, turning off the ignition switch kills the engine. If one is just working with the gauges or igniton, it is fairly easy to leave the switch in the 'on' position after we are done with our tests....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 11-14-2017, 10:36 PM   #22
GB SISSON
GB SISSON's Avatar
STARTED right up!!!! Runs perfect. But I want this vehicle to be able to go down to California to a woodie get together or whatever. Maybe the points and coil survived?
Old 11-14-2017, 10:40 PM   #23
koates
YEP, You were bloody lucky then. Fit that battery cut off switch now, you old fart !! Regards, Kevin.
koates is offline   Reply With Quote
Old 11-14-2017, 11:19 PM   #24
Flowmeister
Flowmeister's Avatar
Hang the key on a nail by the garage door.
Make a point of looking to see if it is hanging there when you go in the house for the night.
Flowmeister is offline   Reply With Quote
Old 11-15-2017, 01:02 AM   #25
Darrell S
Darrell S's Avatar
Speaking of memory, check this out.
https://www.youtube.com/watch?v=9yN-6PbqAPM
Darrell S is offline   Reply With Quote
Old 11-15-2017, 02:03 AM   #26
Graeme / New Zealand
Graeme / New Zealand's Avatar
GB you got a "get out of Jail" card there (for the jail bar)
Wheew!!
Graeme
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 11-15-2017, 06:16 AM   #27
Ggmac
Wire your headlights to the ign switch . If you miss the lights being on it will kill the battery usually before any ignition (expensive ) damage . Of course your battery will take a beating , but a recharge or jump is easy .
CRS only gets worse
Ggmac is offline   Reply With Quote
Old 11-15-2017, 07:21 AM   #28
JSeery
JSeery's Avatar
So you are saying the wire between the coil and distriburer cap? Anything to take the memory thing out of it. ..
As Kevin already answered, one of the small wires connected to the coil. Either the wire from the ignition switch to the coil or the wire from the coil to the distributor points. In your latest case the points must have been open, lucky you! Kevin's suggestion for a cut-out switch is a good one, but I would still remove the coil wire while trouble shooting. You could spend a considerable amount of time working around the car during the day and under the right conditions it doesn't take long to damage something with the ignition on.
Old 11-15-2017, 07:31 AM   #29
chap52
chap52's Avatar
If it were me the follow-up would be when I call AAA for a jump and the driver notices that my new cut-off switch was in the off position.
Glad it is OK...
We all do it, I think?
chap52 is offline   Reply With Quote
Old 11-15-2017, 09:35 AM   #30
GB SISSON
GB SISSON's Avatar
I thank you all for your support and suggestions. I will order up a battery switch. But Flowmeister, what is a key? Actually my my modern 1990's vehicles have them but they stay in the ignition 24/7. The woodie has a push-pull ignition switch on the dash. Maybe I need to address that before I drive to Wavecrest. I've been on this island for 40 years and the locals say the only time they lock their cars is late summer and that's only to keep their friends from filling up their cars with surplus zuchinni. If someone stole a car here, they'd have to wait an hour or more sitting in the ferry line to get it off. Ok, off to that jobsite now.....
Old 11-15-2017, 09:59 AM   #31
corvette8n
corvette8n's Avatar
I was going to walk out to the garage and take a picture of my knife switch mounted on top of my battery and upload it to the barn, duh I moved the car to storage yesterday, picture will have to wait.
Old 11-15-2017, 10:34 AM   #32
adileo
adileo's Avatar
Here’s mine - iphone sideways
File Type: jpg B7999DD9-A3A5-48A2-B23F-6C3C46AFEEB1.jpg (74.1 KB, 86 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 11-15-2017, 10:46 AM   #33
JSeery
JSeery's Avatar
Andy, mind if I rotate it?
File Type: jpg B7999DD9-A3A5-48A2-B23F-6C3C46AFEEB1.jpg (44.7 KB, 71 views)
Old 11-15-2017, 11:03 AM   #34
adileo
adileo's Avatar
Much better thanks Jerry!
Thanks
Andy
1952 F1
Old 11-15-2017, 11:05 AM   #35
19Fordy
19Fordy's Avatar
GB: I've had good luck with the little green cut off switch. Cheap and it works.
It's not real brass.
Old 11-15-2017, 11:17 AM   #36
Crankster
Crankster's Avatar
I was going to mention those "green knob" cutoffs. Was told to avoid those, fwiw, they have only a tiny gauge conductor (made of golly knows what material) at one point in the connection. They do work though.
Crankster is offline   Reply With Quote
Old 11-15-2017, 11:23 AM   #37
Seth Swoboda
Seth Swoboda's Avatar
I too have made this mistake. I now have become OCD about checking, double checking and sometimes triple checking to make sure the ignition switch is OFF. I have even parked in the garage, triple checked, went in to the house and came back out a few minutes later just to make sure it is OFF. I now have a problem that consumes me!
Seth Swoboda is offline   Reply With Quote
Old 11-15-2017, 11:55 AM   #38
carguybill
carguybill's Avatar
FWIW, I have installed a circuit breaker with an additional manual break. This opens and closes all of the electrical system. When I'm done using the car I just press the little red button and the circuit is opened and a little tab drops down. To reactivate I just push up the tab to reset the breaker.
carguybill is offline   Reply With Quote
Old 11-15-2017, 04:28 PM   #39
Bill
Bill's Avatar
GB I know you're thrifty and I remember from your woodie build post that there is a heavy equipment salvage yard near you. Pretty much all pieces of heavy equipment/forestry, excavation and big trucks have a quality battery disconnect switch in the cab or near the battery box. Good quality switches will set you back $100.+/_ Used $20. is fair as it's not a high demand item. Those green ones are junk! Just tryin' to save U a couple a bucks...Bill
Bill is offline   Reply With Quote
Old 11-15-2017, 05:51 PM   #40
Bored&Stroked
Bored&Stroked's Avatar
Boy - I'm glad I have a magneto on my flathead! LOL . . . otherwise this older age crap is going to be HELL! LOL
Glad she started right up.
