Old 07-28-2020, 09:43 PM   #1
DMMuir
Default What kinda needle and seat????
Strange needle and seat? Are these normal??
File Type: jpg 8BB3BDA2-E924-49A1-9A32-F186ABE7AAB9.jpg (31.5 KB, 61 views)
File Type: jpg 855E65FB-78F6-4AE7-88ED-2E529F95241C.jpg (31.5 KB, 54 views)
DMMuir is offline   Reply With Quote
Old 07-28-2020, 09:49 PM   #2
19Fordy
19Fordy's Avatar
Default Re: What kinda needle and seat????
Looks like it might be a Gross Jet set up. I used one on my stock 53 Ford V-8 2 barrel carb and it worked great. Very dependable.
https://www.google.com/search?q=gros...hrome&ie=UTF-8
Old 07-28-2020, 10:23 PM   #3
GB SISSON
GB SISSON's Avatar
I've had one that worked out well and one that didn't. That's a 50% chance of failure where I come from. I have owned probably 75-100 contraptions in my life with a tapered needle and seat and my favorite were with the viton tipped needle. That may have been before ethanol. I never had problems with either brass/steel needles or viton tipped ones unless I was lazy or disinterested and let the contraption sit for a year or two with stale gas in the tank. Offered two otherwise identical carb kits I'd take the one with the old school needle and seat.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 07-28-2020, 11:12 PM   #4
DMMuir
Here is the other pic I meant to attach
File Type: jpeg 4DE0752F-55E7-4CD4-A467-FAA7008AD46E.jpeg (107.6 KB, 48 views)
Old 07-28-2020, 11:54 PM   #5
J Franklin
J Franklin's Avatar
It isn't a grosjet or at least of any type I have seen.
Old 07-29-2020, 11:26 AM   #6
Kube
Kube's Avatar
Yep, Grosejet... I've had a few in the shop due to failure. I'd never considering using one myself.
Oddly enough (to me anyway) they each CLOSED off the supply of fuel.
