Old 05-31-2020, 06:15 PM   #1
Robert/Texas
Robert/Texas's Avatar
Default Light Switch Problem
I bought a “Made in USA” light switch body and a “Made in ???” lighting harness from one of the vendors and tried to install them in my ’28 roadster today. After assembling them together I found that the switch mechanism was jammed.
I'm hoping that someone can help me with this problem.
Thanks in advance, Robert
Robert/Texas is offline   Reply With Quote
Old 05-31-2020, 07:26 PM   #2
DNLs1930
DNLs1930's Avatar
Default Re: Light Switch Problem
Hey Robert,
Are you talking about the switch on the steering wheel being jammed?
If so take the wire harness and switch housing off the steering wheel, make sure the inside wire contact plate is lined up inside the housing (there is an alignment "key and slot") then make sure the horn/light switch "tabs" at the end of the steering wheel are positioned vertical or on Top and bottom not side to side.
Put the switch housing back the steering box (there is an alignment key and slot) and hopefully you can get it all aligned.
I just had this issue yesterday and had to take it all apart a few times to get it just right. Good Luck!!
DNLs1930 is offline   Reply With Quote
Old 05-31-2020, 07:42 PM   #3
ryanheacox
ryanheacox's Avatar
https://www.brattons.com/wire-harnes...al-6-volt.html
Check out the main picture in that link. Two issues with the Bakelite disk, combined they would probably jam your light switch up tight.
Old 05-31-2020, 09:00 PM   #4
burner31
burner31's Avatar
Getting the spider gear and switch to align can be tricky, spider gear set at 12/6 o'clock, switch has to be set like wise, light lever should be at 6 o'clock.
Sometimes takes a few tries to get it just right.
Keith
Shawnee OK
'31 SW 160-B
Old 05-31-2020, 09:01 PM   #5
burner31
burner31's Avatar
Side question...anyone lube their switches?
Keith
Shawnee OK
'31 SW 160-B
Old 06-01-2020, 06:13 AM   #6
DBSHELTON
I usually smear a very light coat of silicone grease on the contacts. Don't know if it helps any but makes me feel better.
DBSHELTON is offline   Reply With Quote
Old 06-01-2020, 06:15 AM   #7
Robert/Texas
Many thanks to all of you.
I think that Ryan hit the nail on the head. It was so hard to get the switch body together that I almost gave up. I finally got the two pins to mate and turn in their slots but then found that the switch innards would not move. I hope that I can get this all apart so I can fix them without destroying anything. That will be my project for today.
Thanks again, Robert
Old 06-01-2020, 08:53 AM   #8
rocket1
They make a grease for electrical contacts(diaelectric grease)good for bulb bases also.
rocket1 is offline   Reply With Quote
Old 06-02-2020, 02:14 PM   #9
Robert/Texas
Thanks again. I followed the Bratton's instructions and smeared a little dielectric grease on the contacts and now the switch operates smoothly.
Robert
Old 06-02-2020, 03:40 PM   #10
wensum
wensum's Avatar
I found that the indents were too deep and had to partially fill them with an epoxy filler, smoothed out before the light switch would work.
wensum is offline   Reply With Quote
Old 06-02-2020, 04:06 PM   #11
Ruth
I smear on a little di-electric grease. I use di-electric grease on all of my electrcal connections to help prevent corrosion.
Ruth
Old 06-03-2020, 09:11 AM   #12
Tinbasher
Tinbasher's Avatar
I went though the same thing. I had bought one switch assembly and it was poorly made. Then I bought a second one from Bratton's. Much better, plus it came with a instruction sheet on what to do to mate it up to the spider at the bottom of the steering column and making the bake light part fit inside the metal housing. One of those little jobs that take time to get it to fit right. Now mine work well. JP
Tinbasher is offline   Reply With Quote
Old 06-06-2020, 05:56 PM   #13
Robert/Texas
Thanks all.
I finally got the time to continue the harness installation. I didn't get far when I discovered that the taillight wires are about 2 feet too short. I thought about splicing about 2 feet into these wires but in addition to this the switch has a scraping feel and no indent feel for the parking, low beams, and high beams. Instead of splicing the old harness, I think I’m going to start over with a Bratton's supplied harness as suggested.
Old 06-07-2020, 09:57 AM   #14
Robert/Texas
I keep on learning. Browsing the Bratton’s catalog I see that they have a 25 inch taillight wire extension for drum taillights. I’ve been exercising the switch and it seems to be freeing up so I’m hopefully going to save some money.
