Old 11-14-2017, 08:22 PM   #1
GB SISSON
GB SISSON's Avatar
Default SO incredibly mad at myself!!!
You may remember I have been troubleshooting my fuel gauge in my homemade woodie. Well, last week I left the ignition swith on for an hour and a half and when I just happened to notice, my new blue bosch coil was really hot. I was so pissed off I promised myself I wouldn't leave the ignition on again.....Well tonight after work I noticed the ignition switch has been on for 3 days. All I can imagine is my fresh Bubba's distributer has burned points, my coil is fried and other horrors yet unknown. Is this what happens when we advance in age? It is on the charger now, but have I ruined something or is this just something that happens? Already had a rough day at work, but I'll get through this. We always do.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 11-14-2017, 08:32 PM   #2
KDL
KDL's Avatar
Default Re: SO incredibly mad at myself!!!
CRS. I know the feeling.
KDL is offline   Reply With Quote
Old 11-14-2017, 08:44 PM   #3
slowforty
slowforty's Avatar
CRAFT is worse
slowforty is offline   Reply With Quote
Old 11-14-2017, 08:49 PM   #4
GB SISSON
GB SISSON's Avatar
Originally Posted by slowforty View Post
CRAFT is worse
What is CRAFT? An urge to buy a hot glue gun and a couple tubes of sequins? Sounds dreadful....
Old 11-14-2017, 08:53 PM   #5
jim1932
jim1932's Avatar
I got in the habit of disconecting the battery everytime I leave the car. granted it is by no means a regular driver.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 11-14-2017, 08:53 PM   #6
petehoovie
petehoovie's Avatar
Can't Remember A Frigging Thing....
Old 11-14-2017, 08:55 PM   #7
JSeery
JSeery's Avatar
I would not leave the ignition on for more than a minute or so max. Longer leads to damage and increases the chance of forgetting about it being on. Even better would be to remove the coil wire if you are going to do extended testing.
Old 11-14-2017, 09:05 PM   #8
KDL
KDL's Avatar
CRAFT is worse
Lol.
Yup. That's more like it.
Old 11-14-2017, 09:06 PM   #9
GB SISSON
GB SISSON's Avatar
Of course I would never leave it on on purpose. I guess I need a dash warning light. I'm gonna go down in a half hour and try to start it.
Old 11-14-2017, 09:09 PM   #10
GB SISSON
GB SISSON's Avatar
I spent two hours today trying to find some sockets I bought to wire up my turn signals. Finally gave up. And no, I am definately not a pot smoker.
Old 11-14-2017, 09:10 PM   #11
JSeery
JSeery's Avatar
I really do think taking the coil wire off anytime your trouble shooting anything other than the ignition system itself is the way to go. Only takes a few seconds and takes the memory element out of it. I've had some memory issues lately that have been really costly!!!
Old 11-14-2017, 09:21 PM   #12
michael a
michael a's Avatar
Maybe at our our ages what the hell would a little reefer hurt?
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 11-14-2017, 09:22 PM   #13
RalphM
RalphM's Avatar
I really like the one when you walk into a room, and forget why your there!
RalphM is offline   Reply With Quote
Old 11-14-2017, 09:24 PM   #14
GB SISSON
GB SISSON's Avatar
So you are saying the wire between the coil and distriburer cap? Anything to take the memory thing out of it. And here I was all excited to get on medicare in May and the cheaper ferry tickets and the free senior lunch at the senior center, not to mention the 25 cent coffee at Macdonalds when I get to the mainland....
Old 11-14-2017, 09:24 PM   #15
koates
Well you may or may not have damaged the coil depending on weather the distributer timing contacts are closed or open. Points closed and coil cooking, points open so no current flow there. Regardless the distributer contacts may survive OK.. All my cars have a battery cut off switch and its always OFF when I walk away from the car. Fit that switch NOW and use it. It also doubles as an anti theft device if you hide it somewhere. And NO not the coil to dist cap high tension cable but the small ignition primary wire at the distributer to one coil small terminal. Regards, KEVIN.
koates is offline   Reply With Quote
Old 11-14-2017, 09:34 PM   #16
GB SISSON
GB SISSON's Avatar
So, Kevin you are saying a battery cut off switch? What's best and easiest?
I'll report soon on my 'start up'
Old 11-14-2017, 09:47 PM   #17
Jack E/NJ
Jack E/NJ's Avatar
An optimist might say there's a 33% chance the points were open with a 30* dwell. 8^) Jack E/NJ
Old 11-14-2017, 09:54 PM   #18
koates
Yes, fit a heavy duty battery cut off switch which breaks the main battery cable or better still the main ground cable from the battery positive terminal if its an original Ford positive to ground system. I try and mount these switches in the floor of the vehicle just in front of the drivers seat so that the floor mat will hide the knob or key. It can be reached fast if there is a wiring short or fire even while you are driving if need be. You don't have to lift the hood so nobody can see you turning it off. Some switches have a removable key or lever. You may have to make or buy battery cables to suit the switch position. Yes I like you tend to forget things sometimes and Im over seventy. Regards, Kevin.
Old 11-14-2017, 10:05 PM   #19
GB SISSON
GB SISSON's Avatar
My wife is making dinner right now, but I bet with my 30 year old charger, my battery is 'half full' by now. I am the eternal optomist.
Old 11-14-2017, 10:23 PM   #20
deuce_roadster
deuce_roadster's Avatar
If you used the switch to shut off the engine, how did it get back to the ON position? Did I miss that?
