09-26-2022, 07:41 AM | #1 |
Rear Window Garnish Removal
Good day. I would like to remove the Rear Window Garnish Molding on my 30 Coupe so that I can re-paint. Question: Upon removing all the screws, will the glass remain in-place? Thanks. Steve
If it aint broke, don't fix it! |
09-26-2022, 09:48 AM | #2 |
Re: Rear Window Garnish Removal
Steves.. I have a '29 Special Coupe, and in my removal of either quarter window or rear, the glass will stay in place if it was properly set. There is a glass setting rubber, from suppliers, to use on installation. Follow re-set instructions and you should be able to accomplish this. .. kb
09-26-2022, 10:13 AM | #3 |
Probley, the garnish does hold the window in place but most likley the glass setting rubber will be somewhat stuck to the body. Might even be a little stuck to the window garnish. Why not just pop the glass out and replace the rubber now ? The new rubber will probley be less $ than the paint your going to use for the garnish's
09-26-2022, 10:40 AM | #4 |
Thanks guys.
09-27-2022, 04:23 PM | #5 |
Are your qtr windows safety plate glass? If not a good time to update. I did my qtr and rear windows a couple of years ago, now have safety plate all the way around.
Joe B |
09-27-2022, 10:53 PM | #6 |
