05-11-2012, 09:35 AM | #21 |
Re: sacrificial anodes
The stuff I use is Molibdium Disulfate (spelling) and is used in the aerospace industry, I do not believe it has copper in it. Never sieze is just a general name, I hope it works. Too late now I'm not taken it apart it runs too good
02-16-2022, 07:38 AM | #22 | |
02-16-2022, 08:43 AM | #23 |
I use the radiator caps with the sacrificial anode attached with a stainless steel wire.
02-16-2022, 08:57 AM | #24 |
2 key points here; 1. 4dford/SC, No-Rosion prevents electrolysis, and is used in the majority of high end antique cars, and my 29 Roadster & 40 coupe, both with aluminum heads. I use it in all my cars, and have for years. No-Rosion is like an insulator, blocking the galvanic corrosion path in the electrolyte, (coolant, and or anti-freeze), between dissimilar metals.
2. Deuce Man, Right on, most anti-seize is copper based. Aircraft anti-seize is graphite & petroletum based and is used where steel contacts aluminum, spark plugs, and steel studs in aluminum heads. "Safe-T-Seize" is sold by Aircraft & Spruce. When I install aluminum heads, I coat the steel head stud shanks and threads with "Safe-T-Seize", and the spark plug threads. The zinc anodes are great backup to "No-Rosion" in the event it is not changed when needed. When you run 2 mechanical temp gauge sender, you are limited to where you can install anodes. |
02-16-2022, 10:29 AM | #25 |
As has been said earlier, use No-Rosion, distilled water and check Ph with the old chemistry strips we used in highschool. There's also a video on U-Tube that shows you how to check PH level using a multimeter. Look here:
https://www.google.com/search?q=how+...client=gws-wiz and https://www.webstaurantstore.com/hyd...gaAgh3EALw_wcB and http://www.no-rosion.com/norosioncoolant.htm Last edited by 19Fordy; 02-16-2022 at 10:42 AM. |
02-16-2022, 11:37 AM | #26 |
And remember, these are sacrificial anodes, and as such, must be replaced on a regular basus. |
