Old 07-03-2022, 05:00 PM   #1
Werner
Werner's Avatar
Default Shortened pitman
Hello at all.
My neck and shoulders have reached an age where steering has become very difficult. I'm considering fitting a shortened Pitman steering arm.
Are there any disadvantages with this? Does anyone have any special considerations for assembly?
I thank you in advance!
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 07-03-2022, 05:03 PM   #2
1crosscut
1crosscut's Avatar
Default Re: Shortened pitman
I don't have personal experience with one but I understand that it will increase your turning radius.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-03-2022, 05:03 PM   #3
AL in NY
AL in NY's Avatar
I had one I sold because I didn't like increased turns of the steering wheel, didn't seem "normal".
AL in NY
AL in NY is offline   Reply With Quote
Old 07-03-2022, 05:35 PM   #4
mhsprecher
mhsprecher's Avatar
I installed one in my 28 roadster because the drag link was rubbing on the tie rod sometimes. The shortened pitman arm solved that problem and it is easier to steer. I have not noticed a difference in turning radius, but it makes sense that that would be the case.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 07-03-2022, 05:36 PM   #5
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Cons: Does increase your turning radius, like when you are parking in a line. (So what).
Pros: Steers almost like power steering! (Nice!).
Ivan in southeast va. is offline   Reply With Quote
Old 07-03-2022, 06:02 PM   #6
Keith True
Keith True's Avatar
I have installed lots of these things,half a dozen for myself and probably a dozen more for other people.On every one the spindles hit the stops with the long arm,and still hit the spindle stops with the short arm.The turning radius can't be different as long as the spindles hit the stops.The wheel winds up with 1/4 to 3/8 more travel.I don't notice it.If you have slop in your steering box you will find the slop much more noticeable,because you have to react to the short arm a little quicker.
Old 07-03-2022, 06:58 PM   #7
Synchro909
Synchro909's Avatar
When my Brother in Law bought his Model A, I drove it home for him. He had never driven an A before. The previous owner had fitted a shortened pitman arm. I found the car almost undrivable because of the slack in the steering. We took off the shortened one and put on a standard one. The car was now very drivable and still is with no other work tot he steering.
I wouldn't have one but it's your car, your life.
Old 07-03-2022, 07:11 PM   #8
nkaminar
nkaminar's Avatar
Werner, I don't have the shortened pitman arm but do have a F-150 box which has a lower gear ratio, making the steering easier. The whole front end has to be tight with no slack at the steering wheel. I suspect that is the same with the shortened pitman arm. I understand the F-150 box may be hard to get in Germany. If you can find one it is worth getting because the sector gear that follows the worm gear is actually a roller and this reduces the friction considerably. There is some modification needed to fit the Model A controls (throttle and ignition advance) and light switch. Mine came with the car so I cannot comment on how much work is needed. I did rebuild my box and that is very technical.
Old 07-03-2022, 07:32 PM   #9
Keith True
Keith True's Avatar
If you have a junk sloppy steering box a shortened arm will amplify it tremendously.I've seen a lot of that with people that buy one thinking they are getting a magic bullet that will cover up all their sloppy parts.I had a Tudor that I bought with a short arm on it,it was a handful to drive.I put a long arm on,it drove OK.Not great,but you could aim the car without working at it.In reality the car had a junk steering box.
Old 07-03-2022, 08:19 PM   #10
Conaway2
Conaway2's Avatar
When I rebuilt the steering box on my roadster 2 years ago, I installed a shortened pitman arm and have been very happy with it. The steering is tight and requires noticeably less effort.
Conaway2 is offline   Reply With Quote
Old 07-03-2022, 08:55 PM   #11
J Franklin
J Franklin's Avatar
I installed one and didn't notice any change.
Old 07-03-2022, 09:05 PM   #12
31a
The front steering needs to be in good tight condition it will increase the turning radius as has been said but it will stir easier I personally like it but it must be done right or not much change
31a is offline   Reply With Quote
Old 07-04-2022, 06:08 AM   #13
kimlinh
Hello Werner
My car is restored including the suspension, so everything is tight. I installed the shorter arm and it does help. The car is easier to drive and I don't notice any negative effects. I don't know what the effect would be on a car with a worn suspension.
kimlinh is offline   Reply With Quote
Old 07-04-2022, 10:39 AM   #14
MAG
MAG's Avatar
One of my cars ('30) has a shortened pitman arm and teflon inserts on the steering mechanism. All steering components rebuilt. It steers almost as easy as my other car ('30) with a F100 steering box installed. Neither of these cars have reduced steering arc.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 07-04-2022, 01:28 PM   #15
GRutter
GRutter's Avatar
Shortened arm does not affect turn radius... It only takes slightly more revolutions of the steering wheel to reach the end stops.
GRutter is offline   Reply With Quote
Old 07-04-2022, 03:03 PM   #16
Robert/Texas
Robert/Texas's Avatar
I installed a shortened pitman arm and Teflon pitman and tie rod ends on my ’28 roadster around ten years ago. The car seemed a little hard to keep in its lane after doing this. With help of this forum, I discovered that the car had a poorly made aftermarket radius rod socket. I replaced this with a new better quality one and that fixed the problem. It still handles nicely today.
Robert/Texas is offline   Reply With Quote
Old 07-04-2022, 03:53 PM   #17
duke36
shortened pit. arms often require an adjustable drag link ; see other threads.
Old 09-05-2022, 02:02 PM   #18
Werner
Werner's Avatar
Guten Abend!
I'm a little confused because I can't find the length measures of the pitman original and shortened.
Who knows?
Vielen Dank,
Werner
Werner
Citroen 11 CV, 1947
Old 09-05-2022, 06:52 PM   #19
Rob Doe
mhsprecher, if your tie rod is dragging across the drag link, I think you might have a worn out front spring??? If you front spring is worn that much, I think the the front in castor is off too. Does your steering wheel return to center when releasing it after making a turn?
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 09-05-2022, 07:28 PM   #20
Rob Doe
I'm no expert on Model A steering, but I replaced the spindle bushings and bearings, the drag link and tie rod parts last winter. Little Bug's steering is now pretty good. She has the short pitman arm.
I too wondered about the wider radius as I had seen comments and found that the backing plates were hitting the extended spindle lock pins as Keith states above. The lock pins are the stops for the steering, right??? My thoughts were that this meant that the worm gear had some extra thread left at each end of the travel with the longer original pitman installed. I believe that the turning radius is unchanged as Keith stated in post #6.
As far as the slack in the steering being magnified at the steering wheel, this makes sense to me. I am familiar with the functioning of bell cranks used in aircraft ailerons control systems. The shorter pitman arm is approximately 1 1/2 inches shorter as I recall. This would mean that the shorter pitman will need to move a greater number of degrees rotation to move the drag link fore and aft the same distance that the longer pitman would move the link with fewer degrees rotation. The short pitman will magnify the slack that is out in front of it, but not slack in the steering box???
Well, I've stuck my neck out this far, I might as well finish lynchin' muhself. LOL
The shorter pitman has the effect of lowering the gear ratio of the steering for the
driver's ease of turning. Kinda like putting a bicycle into a lower gear going up hill.
As for a car that wanders over the road, or even shimmies, I'd check the toe in first.
