08-10-2022, 12:16 PM | #1 |
Distributor identification
I have 2 distributors, the one on the right I just pulled from my 34. The one on the left has been rebuilt, I thought I was going to use it on the 34 till I discovered it has 4 mounting bolts and a 2 bolt coil.. I am thinking it's for a 40 since dad had a 40 also. Can anyone confirm its a 40?
Thanks Terry |
08-10-2022, 12:39 PM | #2 |
Re: Distributor identification
The one on the left is 37-41.
08-10-2022, 02:08 PM | #3 |
08-10-2022, 02:12 PM | #4 |
So both can be used on the 34?
08-10-2022, 02:20 PM | #5 |
Yes but you need the coil and condenser that goes with it.
08-10-2022, 02:25 PM | #6 | |
08-10-2022, 02:38 PM | #7 |
The inner terminal caps are also different.
Keith |
08-10-2022, 02:48 PM | #8 |
With the inner rotor being different, my guess is that he rebuilt it for the 40. I have cleaned up what I took out, found the condensor bad and the coil lead to the resistor lose. I'll put it back together next week and hope forthe best. Thanks for the help.
08-10-2022, 02:56 PM | #9 |
'37 - '41 four hole distributor with two bolt coil...
