03-24-2018, 08:23 AM | #21 |
Re: Model A Gauges
My Neighbor has a gauge that shows the temp, INSIDE & OUTSIDE his HOUSE---LOL
Just send the Dog outside & see if he comes back with COLD or HOT Ears! Bill W.
03-24-2018, 10:22 AM | #22 | |
Re: Model A Gauges
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 03-24-2018 at 10:40 AM. |
03-24-2018, 10:36 AM | #23 |
Re: Model A Gauges
... double post deleted
03-24-2018, 12:54 PM | #24 |
Re: Model A Gauges
In Quality & Reliability Engineering, there is the term 'Mean Time Between Failures' (MTBF). It's a formula that mathematically determines the statistical probability of a system or component failure, and the time frame of that failure.
One of the key variables in this equation is the number of parts used in a system. Effectively, the formula can show that as you add more parts, the system reliability decreases, and the MTBF decreases. More parts equals more failures. Henry knew this very well. I like gauges anyway. However, the failure of a gauge could cause a problem...for example: an oil line could fail between the engine and the oil pressure gauge, potentially squirting hot oil in your lap. I took some steps to mitigate the lower MTBF created by the addition of gauges. In the case of the oil pressure gauge, I made sure to use only top quality materials in the lines, fittings, and clamps. Also, I made certain that the lines are routed and secured to prevent chaffing and vibration (stress fatigue cracks). Also, I added a shut-off valve at the engine block so that the entire oil pressure gauge system can be locked out, but the motor can continue to run. Lastly, the gauge and lines are periodically visually inspected. Did these mitigations eliminate the posibility of a failure? No, but it did, mathematically anyway, increase the MTBF. Only time will confirm the expected results.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
03-24-2018, 01:52 PM | #25 |
Re: Model A Gauges
We did have the 1931 indented cowl here in UK so the RHD steering column support part number AF3520-D was used . An ideal place to mount extra gauges but would mean drilling a mounting hole in the bracket . They do turn up at swap meets but are fairly rare .
John in cool dark Suffolk County England . |
03-25-2018, 04:29 PM | #26 |
Re: Model A Gauges
03-26-2018, 07:38 AM | #27 |
Re: Model A Gauges
Chief said, "The wafting SMELL from the overflow tube, will tell you when it's running TOO HOT"!!
Bill Nose
03-26-2018, 07:54 AM | #28 | |
Re: Model A Gauges
Isaiah B. 1928 all metal Tudor |
03-26-2018, 05:05 PM | #29 | |
Re: Model A Gauges
I did modify (shorten) the gauge holder a little just to get the gauges in the exact spot I wanted them. You may or may not have to do that in your car.
03-26-2018, 05:22 PM | #30 |
Re: Model A Gauges
Carl, thank you so much. I like your setup better than any I have seen yet. I'll have to start saving my plastic bottle money for one of those mounts.
Thanks again for the pictures, Ruth |
03-27-2018, 02:43 AM | #31 |
Re: Model A Gauges
03-27-2018, 11:04 AM | #32 |
Re: Model A Gauges
03-27-2018, 11:17 AM | #33 |
Re: Model A Gauges
Both gauges are Autometer
03-28-2018, 03:45 PM | #34 |
Re: Model A Gauges
Here's a couple photos of my gauge setup. The tach is a 1946 vintage Sun tach that I'm running with an upgraded sending unit. I replaced the 1.35 volt battery with a solid state variable power supply. I like the tach because it looks period Model A and works great.
AL in NY |
03-28-2018, 03:47 PM | #35 |
Re: Model A Gauges
Pictures didn't upload.........here they are:
AL in NY |
06-29-2018, 11:54 PM | #36 |
Re: Model A Gauges
06-30-2018, 11:22 AM | #37 |
Re: Model A Gauges
Ouch!
03-17-2023, 08:50 PM | #38 |
Re: Model A Gauges
Al, is your car a 6V, and if it is, what bulbs did you use? Thx
03-18-2023, 04:20 PM | #39 |
Re: Model A Gauges
I bought the Rexaco water temp gauge from Bratton's and got a black metal gauge cup on Amazon that fit the gauge perfectly and came with a mounting bracket that uses a hose clamp. Clamped it to the top of the steering column. I like it better up high so I don't have to look down low under the dash to see it and helps me keep my eyes on the road.
03-19-2023, 03:00 PM | #40 |
Re: Model A Gauges
Scckayak, yes, my pickup is 6 volts, but I don't use bulbs in them because I drive very infrequently at night.
AL in NY |
