09-27-2022, 02:35 PM | #1 |
Condenser
Where does one find a condenser that is the correct diameter and length for the original 32-36 coil? Napa has a guaranteed fit that is probably correct for a Model A, it certainly isn’t correct for 32-36. Napa part is Echlin FA5 and it is .666 inches in diameter whereas the genuine Ford is .75 inches. Length is about the same for both. I can replace ground strap to fit. Genuine Ford condenser is the one on the bottom.
Thanks, John |
09-27-2022, 05:11 PM | #2 |
Re: Condenser
The only condensers that could fit up like a original are left with two options.... The Carpenter 1937-41 Condenser that you could un solder the original brakcet and solder your original on to.. Issue here is the condenser itself is not very high quality..
The Model A condenser I cut the strap off where it overhangs, grind it smooth and solder on my original strap. It is small diameter but otherwise fits and performs well. |
09-28-2022, 06:45 AM | #3 |
Re: Condenser
I have some NORS 32-36 condensers (Most are Standard Brand) for $15 each.
09-28-2022, 07:09 AM | #4 |
Re: Condenser
Unless your car is a 4 Cyl I would stay away from the model A condensers. They do not have the correct electrical characteristics as the V8 condensers.
09-28-2022, 07:43 AM | #5 | |
Re: Condenser
Went this route after two NOS condensers left me stranded |
09-28-2022, 09:44 AM | #6 |
Re: Condenser
That being said, a .24 μF is probably a better match to a "modern" coil than one rated at .36 μF. And just about every engine out there is using a "modern" coil, since most of the original coils have deteriorated to the state that they are no longer usable. I believe this is the case even for the vaunted "Skip's coils" that are so widely used. |
09-28-2022, 09:53 AM | #7 |
Re: Condenser
Old NOS condensers are usually the WRONG way to go . . . as they've deteriorated over time and are usually bad right out of the box, or will soon go bad.
09-28-2022, 10:31 AM | #8 |
Re: Condenser
Here’s my updated Model A condenser on the top of the photo. Laser welded and never got hot enough that I couldn’t hold in in my hands. This particular one is the NAPA one that has a “Guaranteed Fit”. Ha
John |
09-28-2022, 11:43 AM | #9 |
Re: Condenser
09-28-2022, 12:36 PM | #10 |
Re: Condenser
I'm using this modern condensor that I fitted into the casing of an original '33 to '36 condensor. This turned out perfectly and looks like the original setup when in place on distributor. I've put about 2000 miles on my '35 fordor sedan using this condensor, and so far the engine has not missed a beat. Planning to make more of these for back up and friends who want to try these.
09-29-2022, 05:02 PM | #11 |
Re: Condenser
Wiring diagram for 33 through 36 V8’s shows a red wire connecting to the condenser and the coil. Condenser is shown with a ground. In this attached photo there appears to be a connector on the condenser that is missing a wire. My 36 doesn’t have a wire either. How is the condenser wired up?
John |
09-29-2022, 07:39 PM | #12 |
Re: Condenser
John
The condenser slides into the coil and is held in place by the roundhead slot machine screw, that’s where the condenser derives the power. On the opposite end the soldered on ground strap gets grounded and sandwiched between the distributor and block by one of the mounting bolts, that’s all, there is NO wire that get attached to the condenser. The only wire In that area that gets attached is the Ignition wire to the coil lug. |
09-29-2022, 08:43 PM | #13 | |
Re: Condenser
10-01-2022, 12:07 PM | #14 |
Re: Condenser
After scratching my head, reading everything that was posted on the Barn, doing a lot of reading the mystery has been solved! The culprit is shown here on this message. Engine would run, but wouldn’t rev up much at all. Rube Goldberg engineering at its best! Thanks to all who chimed in and helped.
John |
10-01-2022, 01:01 PM | #15 | |
Re: Condenser
08-10-2023, 09:38 AM | #16 |
Re: Condenser
Reviving an old thread.
I see a couple of you have soldered a strap onto a new model A condenser for use in a '32-'36 distributor. I'm thinking of doing the same thing for my '35 distributor. I like the so-called burnout proof model A condensers sold by Snyders, Brattons etc. They are more expensive, but especially made to take the intense heat of their location in a model A distributor right above the exhaust manifold. I run one in my '31 model A. It seems they would have the best chance of surviving the heat used to solder on a '35 type grounding strap. For those who have done it, are they holding up well? Thanks, Steve |
08-10-2023, 10:58 PM | #17 |
Re: Condenser
Update on my previous post #10 from last year. That magneto capacitor shown in my old post is working like a champ! I'll never use an original stock capacitor again, either old used or NOS, except to salvage the can/case, and use it to mount that magneto capacitor shown in my post from last year.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 08-11-2023 at 11:11 AM. |
08-10-2023, 11:50 PM | #18 | |
Re: Condenser
08-11-2023, 02:09 PM | #19 |
Re: Condenser
Well I had an extra high quality "burnout proof" model A condenser, so decided to try soldering the V8 condenser bracket to it. First the model A bracket was cut off, then the surface tinned. Then the bracket was removed from the dead V8 condenser. First the solder was melted, but found it riveted in place too. So drilled out the rivet and removed it. Then soldered it to the new condenser. The new condenser is slightly smaller in diameter, but should work fine.
The soldering heat had no ill effects on the condenser. It read .246mfd before and after soldering. Then it was put on my Herbrand coil and condenser tester and checked under load with a coil. It worked just fine. So I think I have a suitable replacement. |
08-12-2023, 09:52 AM | #20 |
Re: Condenser
after you change the strap the Model A condenser works fine, i have had one in my 36 pickup for 5 years
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
