Old 09-25-2022, 12:42 AM   #1
Rusty30roadster
Default 32b head gasket help? Which one?
Hello experts! I’m having a hard time finding out which head gasket is best for my 32b 4 banger with a high compression ratio, winfield head. Any advice or can you share product links?, really don’t know what to buy. Thanks in advance.
Rusty30roadster is offline   Reply With Quote
Old 09-25-2022, 12:46 AM   #2
denniskliesen
denniskliesen's Avatar
Default Re: 32b head gasket help? Which one?
Best brand 509G. It’s the GraphTite head gasket. If the head doesn’t have the 2 small steam holes in the middle then that’s the one I recommend.
denniskliesen is offline   Reply With Quote
Old 09-25-2022, 02:00 AM   #3
Synchro909
Synchro909's Avatar
I thoroughly recommend the use of a suitable gasket sealer when fitting any head gasket. Permatex Copper Form a Gasket or Hylomar are my preferences. Follow the instructions on the can and you won't have a problem.
Old 09-25-2022, 08:05 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
I have had no joy running non-metallic composition gaskets on my Model "B" engines. One has a 5.5:1 head and the other has a 6:1 head. The picture shows what happened when I ran a composition gasket with the 5.5:1 head. I only use copper head gaskets, Best 573C.
File Type: jpg A & B Cylinderr Head Gasket Applications 225kb.jpg (77.6 KB, 54 views)
Bob Bidonde
Old 09-25-2022, 12:45 PM   #5
Jim Brierley
Winfield heads, and most after-market heads, require the use of the Model A gasket, my choice is the Best 509 in copper. B blocks need the 4 small holes in the center line of the block plugged FLUSH with the deck. This is not to just plug the holes but mainly to support the gasket. I spray the gasket with silver paint, both sides, a light coat followed by a heavy coat, paint acts as a glue, copper coat never dries so remains slippery. e-mail me at [email protected] if you'd like more info.
Old 09-25-2022, 01:01 PM   #6
CWPASADENA
CWPASADENA's Avatar
I suspect something was not flat or you may have used a composition gasket that is impregnated with silicone and also has the beads of silicone on the gasket. These are notorious about leaking.
I have had excellent results on many A and B engines using the Best gasket with Kevlar. I use spray Copper Coat as a sealer and install the head while the sealer is wet. I also clean the head and block with lacquer thinner to ensure everything is absolutely clean of any oil or grease.
My experience,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 09-25-2022, 09:44 PM   #7
Synchro909
Synchro909's Avatar
My experience,
Chris W.
Ditto all that.
Old 09-25-2022, 11:43 PM   #8
Rusty30roadster
My experience,
Chris W.
Here’s my issue and rationale for head gasket shopping
File Type: jpg D4833B11-7E3A-4889-B75C-AD9A5805712B.jpg (44.7 KB, 56 views)
Old 09-26-2022, 12:52 AM   #9
Synchro909
Synchro909's Avatar
I doubt that is caused by the head gasket. I'd say that the head stud hole goes all the way through to the water jacket - it shouldn't. Some ham fisted spanner jockey has over tightened the head stud and broken out the bottom of the hole. I'd try removing the stud, sealing the thread, then re inserting it and re tensioning it.
Old 09-26-2022, 12:53 AM   #10
Synchro909
Synchro909's Avatar
Even some radiator sealer in the water would do.
Old 09-26-2022, 07:36 AM   #11
old31
Bob, are you also going with 60-65 psi on the water pump studs? Post #4.
old31 is offline   Reply With Quote
Old 09-26-2022, 07:38 AM   #12
old31
I agree with syncro 100% on the # 8 post.
Old 09-27-2022, 08:16 AM   #13
old31
So, what is your vote on the gasket for a Snyders 6.1 head. Snyders says they are all for the HC head. Do I want steam holes or not?
https://www.snydersantiqueauto.com/p...9902&cat=41689
https://www.snydersantiqueauto.com/p...d=979900&cat=0
Old 09-27-2022, 01:47 PM   #14
denniskliesen
I only use this gasket and pretty much have followed the same procedure CWPASADENA does to install. Believe it or not, that leaking stud and nut shown above could have been prevented with spray on sealant and instructed from BEST gasket. Definately do not use the premium gasket.
Old 09-28-2022, 08:56 AM   #15
Bob Bidonde
My engine was a new rebuild and the cylinder head was new too. Flatness was not the issue. It was the gasket!
Bob Bidonde
Old 09-28-2022, 10:11 AM   #16
katy
katy's Avatar
Originally Posted by Synchro909 View Post
I doubt that is caused by the head gasket. I'd say that the head stud hole goes all the way through tot he water jacket - it shouldn't. Some ham fisted spanner jockey has over tightened the head stud and broken out the bottom of the hole. I'd try removing the stud, sealing the thread, then re inserting it and re tensioning it.
Ditto
Old 09-28-2022, 11:30 AM   #17
Dave in MN
Dave in MN's Avatar
Bob,
Did you use a mixture of water and antifreeze as the coolant or just water when first starting the engine?
Dave in MN is offline   Reply With Quote
