Old 07-23-2019, 07:30 AM   #1
flathead48
Default 94 carb top
Some of the tops I found have this hole punched out. Are they junk or is there a reason for it. Thanks, Rick
File Type: jpg FD65C343-5F80-4091-8256-ED063D4F0061.jpg (30.0 KB, 32 views)
flathead48 is offline   Reply With Quote
Old 07-23-2019, 08:05 AM   #2
Kube
Kube's Avatar
Default Re: 94 carb top
That's a vent for the pump housing. This particular top is for '39 - '40.
Kube is online now   Reply With Quote
Old 07-23-2019, 10:18 AM   #3
flathead48
Thanks for the info.
Old 07-23-2019, 10:43 AM   #4
40 Deluxe
That is the float bowl vent. Every carb needs, and has, one. Older carbs, like this one, had external vents. Newer carbs have internal vents, often a tube sticking up under the air cleaner.
Old 07-23-2019, 11:38 AM   #5
flathead48
40 Deluxe Yes I have both was not sure of vent hole thanks to you and kubes40
For the quick response.
