04-15-2019, 08:43 PM | #1 |
shaft play
I need some advice. I started my 1930 model A truck tonight for the first time this year. The motor sounds great but it had a vibration and made an ungodly sound when revved up. had my wife come out and had her rev it up and give it some R's. I narrowed it down to the water pump shaft. I could wiggle the four blade fan and shaft in and out.
My question is, is there any way by taking the four bolts out of the pump to slide it and the blades out without removing the radiator? I imagine I will have to put new thrust washers and felts in. I would appreciate any help.Thanks Bob |
04-16-2019, 02:10 PM | #2 |
Re: shaft play
The 4 blade fan is not a fix for anything nor is is it more serviceable, actually less serviceable. This is a situation where "if it's in your way, remove it." If you don't want the 4 blade after you put in the aluminum 2 blade, cut off 2 blades and R&R is easier. Tests have shown that the 2 blade moves more air than a 4 blade. If you are partial to the 4 blade, get out the tools. Also. the fake stud and nut kit is great but you have to be able to remove the old studs and that can be daunting.
04-16-2019, 04:23 PM | #3 |
Re: shaft play
I would have no problem with putting a 2 blade on. I'm just trying to get a smooth runner. I'm not partial to the 4 blade. I am a little confused in your comment about fake nuts.
All I asked was does the radiator usually have to come out? |
04-16-2019, 04:43 PM | #4 |
Re: shaft play
If I remember right...if you have studs holding the pump on I think it does. If you used bolds then I think you just pull it forward and then remove the pump.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
04-16-2019, 05:27 PM | #5 |
Re: shaft play
Thanks for the help. I'll check to see if they are bolts or studs.
04-16-2019, 06:14 PM | #6 |
Re: shaft play
Steve Hanna, Polk City, IA Last edited by sphanna; 04-16-2019 at 06:15 PM. Reason: spelling |
