Old 11-22-2018, 04:44 PM   #1
30 Closed Cab PU
Default Report Button
Have noticed my posts, and some other's posts has a green report button/indicator. What does this indicate, perhaps we have had had someone report us?
30 Closed Cab PU is offline   Reply With Quote
Old 11-22-2018, 04:47 PM   #2
rfitzpatrick
Default Re: Report Button
think it means your 'on-line'?
rfitzpatrick is offline   Reply With Quote
Old 11-22-2018, 04:51 PM   #3
30 Closed Cab PU
Looks like you are correct, I tried hovering my mouse over the indicator and an on/off line box displays. Did not occur to me previously to try the hover mouse over the indicator.
Thanks
Old 11-22-2018, 08:34 PM   #4
Brian SATX
Brian SATX's Avatar
Believe the Report Bar is to notify the admin that this might not be an appropriate comment.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 11-22-2018, 10:29 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
That's it. If someone finds your post offensive, in the wrong area, advice that can cause injury, you hit the report button, send a message to the admin about the post. But don't mess around with it too much, use it too much and you are the trouble maker and will suffer the consequences.
Old 11-22-2018, 10:54 PM   #6
Bill G
Bill G's Avatar
The fact that the green "on-line" light and the report button are next to each other is simply a coincidence.
Bill G is offline   Reply With Quote
