Old 11-19-2017, 02:12 PM   #1
Mikeinnj
Mikeinnj's Avatar
Default 30 Pickup rear window
Anyone have any tips for installing the rear window glass, frame ,four corner pieces and the gasket, nuts and bolts on a 30-31 pickup truck ?
Looks like a challenge !
I appreciate any comments.....Mike
Mikeinnj is offline   Reply With Quote
Old 11-19-2017, 02:54 PM   #2
Larry Jenkins
Default Re: 30 Pickup rear window
Brace?
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 11-19-2017, 03:16 PM   #3
George Miller
George Miller's Avatar
It is a challenge, getting all those bolts in. Good luck.
George Miller is offline   Reply With Quote
Old 11-19-2017, 05:02 PM   #4
Bob Grieb
Bob Grieb's Avatar
Send a message via Yahoo to Bob Grieb
I recently installed a new window in my 30 Pickup and it was a challenge. I had to do it twice because I failed to stretch the rubber around the window and tack it in place before I did the installation. That resulted in puckers in the rubber. I had some help from the forum with folks defining how to do the stretching operation. I will go look for that information and come back here with the info. I also bought new hardware and installed the screws lightly until all were in place before tightening them all. additionally I modified lightweight wrench so I could hold the nuts in place while I started the screws.
It was a labor intensive process. Good Luck!
Bob
1929 Tudor
1930 Pickup
Bob Grieb is offline   Reply With Quote
Old 11-19-2017, 05:20 PM   #5
Bob Grieb
Bob Grieb's Avatar
Mikeinnj
If you go to the link below you can read the post on my issue replacing the rear window. Hope it helps.
Bob
https://www.fordbarn.com/forum/showt...on#post1554421
1929 Tudor
1930 Pickup
Old 11-19-2017, 05:22 PM   #6
Bob Grieb
Bob Grieb's Avatar
Did not work. I will try another way.
1929 Tudor
1930 Pickup
Old 11-19-2017, 05:29 PM   #7
Bob Grieb
Bob Grieb's Avatar
I think the link below will work this time. It describes the problem I had and the help I received.
https://www.fordbarn.com/forum/showt...ng+rear+window
Bob
1929 Tudor
1930 Pickup
Old 11-19-2017, 05:30 PM   #8
SteveB31
SteveB31's Avatar
Install the glass, rubber seal, and all 4 corners on the workbench. Then install in the truck. Duct tape or a helper is helpful. Why Ford used 22 screws to install one window is beyond overkill.
SteveB31 is offline   Reply With Quote
Old 11-19-2017, 11:57 PM   #9
verdirick
Smile Re: 30 Pickup rear window
I used a pair of curved needle nose pliers (Harbor Freight specials) to hold the nut in place while turning the screw with magnetic screwdriver. Was a challenge but it worked.... Good luck
verdirick is offline   Reply With Quote
