Old 05-11-2017, 07:29 AM   #1
petew
petew's Avatar
Default Alignment Specs
Looking for front end alignment specs for my 51 Ford using radial tires.
I found some older threads where it was discussed but nobody ever posted actual specs.
petew is offline   Reply With Quote
Old 05-11-2017, 02:48 PM   #2
toby
toby's Avatar
Default Re: Alignment Specs
From the 49-51 Shop Manual
Caster:
Max. 1/2 Degree, Min. -1 Degree
Camber:
Max. 1 Degree, Min. 0 Degree
King Pin Inclination Degrees:
Max. 5 3/4 Degrees, Min. 4 3/4 Degrees
Toe-in Front Wheels (Inches):
1/16 to 1/8
I just set my Toe-in on my Coupe. Been doing great with radials.
toby is offline   Reply With Quote
Old 05-11-2017, 03:50 PM   #3
petew
petew's Avatar
Thanks Toby for those specs.
What are people doing about the special wrenches needed to set the caster and camber ?
