Old 01-25-2016, 09:21 PM   #1
Pete
Pete's Avatar
Default Today's triva question.
What is it?
Old 01-25-2016, 10:00 PM   #2
Binx
Default Re: Today's triva question.
I dunno but there are too many twists per inch in the safety wire making it brittle and the grade 8 bolt is probably overkill.
Lonnie
Binx is offline   Reply With Quote
Old 01-25-2016, 10:06 PM   #3
RalphM
RalphM's Avatar
Distributor block off? Or some type of freeze plug.
RalphM is offline   Reply With Quote
Old 01-25-2016, 10:23 PM   #4
JSeery
JSeery's Avatar
Does look like a freeze plug????
Old 01-25-2016, 10:26 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
A device to prevent loss of your favorite allen and hex bolt
Old 01-25-2016, 10:33 PM   #6
Pete
Pete's Avatar
Partially right.
Old 01-25-2016, 10:35 PM   #7
Pete
Pete's Avatar
Lonnie
That is the standard twist for this application with this wire.
There can be no overkill on this application.
Old 01-25-2016, 10:43 PM   #8
Lawson Cox
Lawson Cox's Avatar
A thingamajig or do hicky one. Hard to tell.
Old 01-25-2016, 11:00 PM   #9
Drbrown
Drbrown's Avatar
A flywheel/damper for a toilet paper dispenser.
Drbrown is offline   Reply With Quote
Old 01-25-2016, 11:15 PM   #10
swoopNZ
MEMBER EMERITUS
An Australian heavy duty contraceptive device.
swoopNZ is offline   Reply With Quote
Old 01-25-2016, 11:55 PM   #11
JM 35 Sedan
JM 35 Sedan's Avatar
Looks like a special aluminum or steel plug made to seal off the fuel pump push rod area in a Flathead engine, by using the tension of valve guide retainer/crows foot, held in place by a hex head machine screw, and a hex head bolt through plug, and threaded into plug to block off hole for mechanical fuel pump push rod. The saftey wire feature is to help keep hex head bolt from backing out
John
Old 01-26-2016, 12:41 AM   #12
ford38v8
ford38v8's Avatar
The photograph is of a clever device created for the sole purpose of quietly entertaining the old man where confined by Mama to the computer room. Mama's peace of mind thus preserved for an indefinite period, she is enabled to proceed with her daily toils cleaning up after the old man.
Alan
Old 01-26-2016, 06:20 AM   #13
47Merc
A nose piercing lug for an eighteen year old girl with tatts on both legs.
47Merc is offline   Reply With Quote
Old 01-26-2016, 08:37 AM   #14
millersgarage
millersgarage's Avatar
safety wire practice device.
millersgarage is offline   Reply With Quote
Old 01-26-2016, 10:17 AM   #15
Bruce Lancaster
Block off for oil pump hole for an external dry sump setup.
Bruce Lancaster is offline   Reply With Quote
Old 01-26-2016, 12:15 PM   #16
rowens55
rowens55's Avatar
I vote for thingamajig.
Rowen
Alive n kickin n mostly kickin!
rowens55 is offline   Reply With Quote
Old 01-26-2016, 12:28 PM   #17
Willit Stop
Willit Stop's Avatar
It's a redneck CD player (needs work).
Willit Stop is online now   Reply With Quote
Old 01-26-2016, 01:55 PM   #18
Pete
Pete's Avatar
Bruce gets the seegar.
Old 01-26-2016, 02:17 PM   #19
Bruce Lancaster
With Pete, the raciest answer is always the correct one!!
Old 01-26-2016, 06:24 PM   #20
Royal Ryser
Her tatts were on her legs? Never saw them there before.
Royal Ryser is offline   Reply With Quote
