Old 04-20-2014, 09:33 PM   #1
Alex Dragone
Default Where to find a distributor cap for Mallory dual point distributor
I am looking for a new cap for my Mallory dual point distributor for my A. Does anyone know where I might find one? I have most of the original, it was broken before I got it and I would like to try this thing out on my car.
Alex Dragone is offline   Reply With Quote
Old 04-20-2014, 09:46 PM   #2
SteveB31
SteveB31's Avatar
Default Re: Where to find a distributor cap for Mallory dual point distributor
What Model Mallory is it?
SteveB31 is offline   Reply With Quote
Old 04-20-2014, 09:54 PM   #3
colin1928
colin1928's Avatar
Which model Mallory dizzy is it
if it is the later style try Sacramento Vintage Ford
If early try So-Cal speed shop Cal
I have also heard that Bosch have 1 that will work
colin1928 is offline   Reply With Quote
Old 04-20-2014, 10:18 PM   #4
Alex Dragone
Where do I look to find what model it is? I will post pictures in a moment
Old 04-20-2014, 10:26 PM   #5
Alex Dragone
Here are some pictures of it, its much larger than a stock Model A distributor. There is a part number on the bottom: 20104. Also shouldn't there be a pin like a stock distributor to keep it from rotating? or does it just slide in as is and the lock screw holds it in place?
Old 04-20-2014, 10:33 PM   #6
SoCal_Alden
SoCal_Alden's Avatar
This was discussed several years back:
http://www.fordbarn.com/forum/showthread.php?t=44255
Hope this link helps.
SoCal_Alden is offline   Reply With Quote
Old 04-20-2014, 10:34 PM   #7
Alex Dragone
Forgot to attach pics
Old 04-20-2014, 10:44 PM   #8
colin1928
colin1928's Avatar
Does it look like this
Locks in same as stock A/B Model dizzy
Old 04-20-2014, 10:47 PM   #9
colin1928
colin1928's Avatar
You want the early style
Old 04-21-2014, 09:58 AM   #10
1931 flamingo
1931 flamingo's Avatar
Try "BUBBA" over on the EV8 forum.
Paul in CT
Old 04-21-2014, 01:49 PM   #11
Bruce Lancaster
I think that is a super early Mallory...it has the seat for the electrolock.
First generation, released about '29, had that and also hooked to original advance as well as having centrifugal. This one lacks the manual advance but I think is super early, and what you have is likely all you will find!
Bruce Lancaster is offline   Reply With Quote
