Old 04-09-2014, 05:57 AM   #1
1946
1946's Avatar
Default Upper steering bush
I have seven tooth steering gear and would like to remove the upper bushing. The bush is not in the best of condition but the rest of the assembly is reasonable. The controls require new anti-rattle bushes and to be streightened. My question is what is the recommended method of removal, quickest, and the least destructive. Thank you all in advance for your help.
Tassie Devil
1946 is offline   Reply With Quote
Old 04-09-2014, 06:28 AM   #2
700rpm
700rpm's Avatar
Default Re: Upper steering bush
These are pot metal and have often swollen over the years. I removed the set screws, inverted the column after removing all the lower mechanics and control rods, and used a long 2" wooden dowel to tap the bushing out the top. I have also had to drill and cut them out. They can be difficult.
Ray Horton, Portland, OR
Old 04-09-2014, 07:17 AM   #3
Mighty1924
Mighty1924's Avatar
I have a 2 tooth and need to replace the upper bushing also.
My question is can I remove the column only and leave the steering box attached to the frame. Or do I need to loosen the entire column before I slide off the column?
Mighty1924 is offline   Reply With Quote
Old 04-09-2014, 07:25 AM   #4
Joe K
Joe K's Avatar
On the 2 tooth you CAN remove the clamp directly above the two tooth box and thereby remove the tube. BUT you have to have room in your car to pull the tube/sector/spark-throttle levers upwards into the car.
Steering wheel is OFF of course. As would be the clamp attaching the column to the gas tank.
You might undo or remove the two bolts holding the two tooth box to the frame to allow the column to "lower" a bit to secure more space for the withdrawal.
At this point it makes sense to simply remove the whole column to the workbench - while there you can "touch up" the adjustment and remove some free play on the 2 tooth box. Floorboards have to be out for this, of course.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 04-09-2014, 07:42 AM   #5
Mighty1924
Mighty1924's Avatar
Thanks for the responce Joe.
I will give it a try this week end.
Rick Shaw.
Old 04-09-2014, 08:48 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Rick Shaw.
Do you have a car where the top folds down? Otherwise I'm not sure there is room to just slide the tube off.
I've done the same as Ray to remove the top bushing. I've also put a one foot long solid steel bar inside the column and shake it up and down to knock out the bushing.
Old 04-10-2014, 02:23 AM   #7
1946
1946's Avatar
Thanks to all who replied. It looks like I will have to remove the lower brass bush first then knock out the upper bush with a larger drift. Will give it a try and see what happens. Again many thanks to all....Great place this Barn for information!
Tassie Devil
