Old 04-20-2014, 10:53 AM   #1
Alex Dragone
Default New Distributor (Locating pin) doesn't fit
I purchased a brand new distributor for my car and the pin in the bottom of the distributor that fits into the top of the head is too large in diameter to fit into the hole in the head. So, my question here is should I take the time to file the pin down or should I just drill the hole larger in the head? I would really hate to drill the original hole out to a larger size for a reproduction part. Any thoughts on this?
Alex Dragone is offline   Reply With Quote
Old 04-20-2014, 11:09 AM   #2
redmodelt
redmodelt's Avatar
Default Re: New Distributor (Locating pin) doesn't fit
Try just cleaning the hole out first. Then make sure the tangs are going into the lower shaft when you install the distributor.
Old 04-20-2014, 11:12 AM   #3
Mitch//pa
also lube the distributor base and also the hole in the head. a little extra friction could stop it from dropping down.
i never had a problem with the repo dist assy in that regard
Old 04-20-2014, 11:24 AM   #4
Jim/GA
Jim/GA's Avatar
I had this problem. After I cleaned out the hole in the head, I filed the pin.
Jim Cannon
"Have a Model A day!"
Old 04-20-2014, 12:07 PM   #5
Charlie Stephens
Hit the pin with sandpaper to check for burrs. Don't drill the head but do check the hole for burrs. Maybe clean up the hole but don't make it larger. Try the distributer is another head (I have one you could borrow since you probably live close, all kidding about living close, where in general are you located?) to see if it fits. If there is still a problem, call the supplier and send it back. If we accept junk we deserve what we get.
Charlie Stephens
Old 04-20-2014, 12:59 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
My original distributor pin measures .243", so I'd imagine the head hole is 1/4" and you could use a 1/4" bit to clean it out.
Old 04-20-2014, 09:29 PM   #7
Alex Dragone
Thanks everyone for the great advise. I will try cleaning the hole first with some sand paper and if that doesn't work I think I will just file the pin until it fits. The pin on the new distributor is clearly larger than the pin on the old one (visibly larger without measuring).
Old 04-20-2014, 10:23 PM   #8
Charlie Stephens
As discussed in post #6, please don't use anything larger than a 1/4 drill.
Charlie Stephens
Old 04-20-2014, 10:56 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Dog here, Jist use the pin frum the OLD dizzy!!
"THE ASSISTANT GURU OF STUFF"
Old 04-21-2014, 10:12 AM   #10
P.S.
If that is one of the NEW distributors, not a rebuilt.... I had the same situation. Found that when they sent the distributor shells to be powder coated, they didn't mask off the pin and the powder coat made it too big to fit in the hole in the head. Had to file off the powder coating and get the pin back to bare metal. Then it fit perfectly.
P.S. is offline   Reply With Quote
