02-01-2021, 02:55 PM | #1 |
Napa part number for 41 fan belt
Can anyone tell me what the Napa part number is for a fan belt for a 41 ford coupe? Stock pulleys,6 V 42 generator. I have one from C&G it’s V shaped with ridges.
"I have built my organisation on fear"..Al Capone. |
02-01-2021, 03:13 PM | #2 | |
Re: Napa part number for 41 fan belt
Don't know what you mean by "V shaped with ridges" The belts are supposed to be 'V' shaped and some have relief grooves. The belt should be 54 3/8"long x5/8" wide. Check Napaonline.
02-02-2021, 08:10 AM | #3 |
Not sure if it's the same as my '35 = NAPA B54. It's 56 3/4" long.
02-02-2021, 01:51 PM | #4 |
I have a DAYCO No. 22528 belt on my '41. It fits perfect and has been on for 7 years now.
02-02-2021, 01:54 PM | #5 |
I forget who this came from, somebody here on the Barn nice enough to share it.
Wayne |
02-02-2021, 01:59 PM | #6 |
02-02-2021, 02:20 PM | #7 |
Not sure if the 41 belt arrangement is the same as I have for my C59A, but for the crank/water pump/ generator belt I went with the Gates B54/55 belt. My crank pulley is no good so I can’t fit it onto the crankshaft to get an exact fit, but I think either will work with the generator adjustment range.
