Old 07-15-2015, 04:54 PM   #1
petew
petew's Avatar
Default Pinion Bearing Crush Collar
I have a loud rear end in a 1955 Sunliner , sounds like pinion bearings to me. Seems that the necessary bearings are availible but I can't locate a crush collar . Anybody know where I might find one ?
petew is offline   Reply With Quote
Old 07-15-2015, 06:55 PM   #2
rick55
rick55's Avatar
Default Re: Pinion Bearing Crush Collar
I would be surprised if joblot auto couldn't help.
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 07-15-2015, 08:19 PM   #3
WestCoast
check with van pelts
WestCoast is offline   Reply With Quote
Old 07-16-2015, 07:59 AM   #4
Motorhead6
You can use shims and re-use the one you have. The issue is that you attain the specified minimum torque at the prescribed pre-load. It may take a time or two to get it right, but shouldn't take that much time and effort. Usually just add about .020" to .030" will work. You don't have to completely disassemble the unit to change shims, just remove the yoke and add shims until you get it right. You can get shims of various thickness at a John Deere dealer. Just be sure you know the inside and outside diameters of what you want. buy several just to be sure you don't have to go back.
Motorhead6 is offline   Reply With Quote
Old 07-16-2015, 08:17 AM   #5
Rowdy
I have afew crush collars. Do you have the dimensions of the one you need? Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
