11-24-2021, 12:20 PM | #1 |
starter amps
I am trying to determine how many amps my starter draws when starting my car. I have a clamp on ammeter gauge and want to know how to test is. What procedure do I use? What should the starter draw during startup? My car doesn't start until I take my foot off of the starter button.
11-24-2021, 01:43 PM | #2 |
Re: starter amps
Hello, make sure you have large diameter battery cables , can’t answer the amount of draw , but the older 6 volt system are larger than the 12 volt, the small cables are what I first look at on starting problems.
11-24-2021, 05:35 PM | #3 |
Re: starter amps
Just disable the primary circuit, such as, placing something plastic/cardboard etc between the points contact.
Place your ammeter across/around the starter cable. Hit the starter and read the ammeter. On 6v the draw should be under 450 amps. On 12v 250 amps. It kinda sounds as if there is something drawing on the system which is not allowing enough electrons to the points. In other words the starter may be taking everything and when the starter is stopped spinning there is enough power to the points to allow the engine to start. As mentioned, if 6v, make sure the battery leads are heavy enough to handle the load. The should be at least #1, however even bigger is 'more better'. Last edited by Patrick L.; 11-25-2021 at 07:54 AM. |
11-24-2021, 07:47 PM | #4 | |
Re: starter amps
BTW, the current for a 12 volt system will be double that of a 6 volt system if the starter hasn't been modified. That is, it will have 4 times the power. That's why they don't like 12 volts for long. Even the 5/8" shaft will eventually bend if 12 v is put through a 6 v starter. I've seen it too many times.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 11-24-2021 at 07:53 PM. |
11-25-2021, 07:56 AM | #5 | |
Re: starter amps
Oops. gotta start proofreading. Glad you saw that. I meant, 250 amp for 12v system. |
11-25-2021, 03:24 PM | #6 | |
Re: starter amps
Resistance (R) is calculated by dividing the voltage (V) by the current (I). R=V/I. Clearly if you double the voltage, the current doubles to keep the resistance (R) the same. The power of an unmodified starter on 12 volts is 4 times what it is on 6 volts. Power (P) is V x I. If bother have been doubled, the P is increased by a factor of 4. That is why an unmodified starter running on 12 volts will turn over the motor so fast, the fan would nearly pull the car along!! I expect the cranking current on 6 volts to be about 180-220 amps and double that for 12 volts.
11-25-2021, 07:11 PM | #7 | |
Re: starter amps
Doesn't work that way. Many folks think it does. |
11-25-2021, 07:57 PM | #8 | |
Re: starter amps
12 volts 250 amps is equal to 6 volt 500 amps. When you double the voltage you only need half the amperage. Bill |
11-25-2021, 12:15 AM | #9 |
Re: starter amps
My own experience:
The starter would turn over normally, but the engine would not fire until I took my foot off the starter. I did not suspect any problem with the battery. I cleaned the cable connections and all electrical connections with no improvement. I finally replaced the battery and that solved the problem. I don’t have the technical explanation for this. I just know what worked for me. W. Michael |
11-25-2021, 12:28 AM | #10 |
Re: starter amps
you cannot measure current with a Clamp-On Ammeter on a DC circuit. They are designed for AC circuits. In a DC Circuit, the ammeter would need to be in series with the load.
DO NOT ATTEMPT to hook an ammeter in series with the starter. Due to the high current, the ammeter will not survive and could be dangerous if not properly fused. |
11-25-2021, 02:20 AM | #11 |
Re: starter amps
There is a starter draw tester which is an inductive ammeter . You hold it against the starter cable while engaging the starter and it measures the draw in amps. As previously mentioned 6 volt should be under 450 , 12 volt should be under 250.
Bill |
11-25-2021, 07:58 AM | #12 | |
Re: starter amps
It depends on the type he is trying to use. I have one that works on DC. I bought it specifically for testing starters on a vehicle. |
11-25-2021, 02:20 AM | #13 |
Re: starter amps
I had to have my starter replaced this last year, as it was drawing too much current, and my car was hard to get started. I had it tested and they then determined it was the starter itself. Once a new starter was installed it fired right up.
11-25-2021, 02:37 AM | #14 |
Re: starter amps
running free--no load 2700 rpm 50 amps @ 6V
locked --14 ft lbs 0 rpm 3.75 volts 560 amps cranking --engine 100 rpm . 225 amps ,4.75 volt brush spring -35-40 oz |
11-25-2021, 09:53 AM | #15 |
Re: starter amps
Some amp meters use the Hall effect to measure current flow. They will work on AC or DC current. There will be circular magnetic fields around any conductor that has current flowing through it.
If the starter is using up all the battery current on the start phase then the battery's capacity is severely limited. A way to check for a battery problem is to turn on the headlamps before a start attempt and see what they do while the starter is engaged. If the lights dim almost to no light output at all then there is either a problem with the battery or the starter. A good battery has a lot of cold cranking amps available if it's in good condition. This is a basic poor man battery load check. If lights come back up bright after the attempt then I'd check the starter. If the headlamps stay dim then it's likely the battery. |
11-25-2021, 10:09 AM | #16 |
Re: starter amps
"Less than 250" sounds a little too vague to me, but I don't know for sure. These sound like OHV V8 numbers. A Flathead or early Ford in stock form at least, is not a high compression engine, I would think it would (or should) be considerably less than this. Probably closer to 150 amps?
For all that, a voltage drop test of both sides of the starter circuit would be useful. One probe placed on battery + POS post, the other to starter terminal (assuming NEG ground) should not exceed 0.5 volts whilst cranking starter. Same test performed from - NEG battery post to a clean portion of starter case should not exceed 0.2 volts. Note that these are positive voltages, any voltage displayed on the meter represents electrons finding the voltmeter itself an easier path around than any loose, corroded or high resistance connections. High current low voltage DC starting and charging systems find almost any resistance however small to be a major defect, and as a practical matter almost impossible to measure effectively, so a "voltage drop test" has long been used instead to infer excessive resistance. |
11-25-2021, 11:29 AM | #17 | |
Re: starter amps
11-25-2021, 11:35 AM | #18 |
Re: starter amps
11-25-2021, 12:34 PM | #19 | |
Re: starter amps
There ya go ! That one looks a whole lot newer than mine ! Everything ends up showing its age. |
11-26-2021, 08:17 AM | #20 |
Re: starter amps
I always think of it as current draw. In other words, a load like a series wound electric starter motor will only draw the current it needs to function. The amount of current needed will vary depending on the torque it needs to turn and the condition of the motor. The voltage is just the electromotive force that the current uses to flow. A higher voltage will allow for less current being needed to do the same job even though the current changes same as the voltage so it's not quite proportional. The 6-volt starter will certainly turn faster if not modified to work with the higher voltage but it still won't have to draw as much amperage with twice the amount electromotive force and current available to it. It would have around 4X the power as on 6-volt.
