06-21-2022, 10:28 AM | #1 |
No brake lights! Lets fit a mechanical switch. Common hydraulic switch failure.
I realised I had a problem with the hydraulic brake light switch on the 32 Sedan. It isn't very old and I had seen them fail before. I needed a quick reliable fix so I decided to fit a heavy duty microswitch. Watch along and see how it goes.
Mart. https://youtu.be/syvgfst0nRA |
06-21-2022, 12:38 PM | #2 |
Re: No brake lights! Lets fit a mechanical switch. Common hydraulic switch failure.
Mart,
Funny you started a thread on this, I was considering switching from a pressure switch to a mechanical contact myself. I really have press on the pedal to have it activate and it's the Harley Davidson one. I was going to use the lever one Mac's sells, #13480- UNIV, but it breaks (N.C.) when the lever is moved. It's the opposite on what is needed, close on movement, which is N.O. I'm still pondering what to do. |
06-21-2022, 02:08 PM | #3 |
If you are running silicon brake fluid you will need a special switch, regular switches will fail shortly. Try Ron Francis WireWorks: (800) 292-1940. I have found the quality hydraulic switches to be reliable and would suggest keeping yours.
Charlie Stephens |
06-22-2022, 10:48 AM | #4 |
I had two Ron Francis switches fail, not worth the money in my opinion. Use a Napa SL129 switch from a '50's Chevy pickup, they screw right to the toe board and have a nice long arm the brake pedal will trip.
06-22-2022, 11:08 AM | #5 | |
Something SIMILAR in theory to this? Coop |
06-23-2022, 12:52 AM | #6 |
06-23-2022, 10:00 AM | #7 |
06-23-2022, 09:01 PM | #8 | |
And we're still pondering what your abbreviations (N.C.) and N.O. are supposed to mean. (The devil made me do it.)
06-23-2022, 09:04 PM | #9 |
Yeah. Almost nearly but not quite hardly, Coop. LOL
06-23-2022, 09:49 PM | #10 |
06-24-2022, 12:22 PM | #11 |
