06-05-2022, 07:41 AM | #1 |
Alternator
Hi guys was going to install a one wire 6 volt alternator on my tudor. Any recommendations on a good Amp range to go with and or stay away from? I see them from 30 amp and up. Would greatly appreciate any input.
06-05-2022, 08:01 AM | #2 |
Re: Alternator
Lenny, this may help you decide. I use 60 A alternators in my cars because of halogen headlights, sealed beam fog light, electric windshield wiper motor, heated seats and other modern plug-ins.
Bob Bidonde |
06-05-2022, 08:16 AM | #3 |
Re: Alternator
Thanks Bob! I will upgrade lights as well so that is very helpful
06-05-2022, 08:34 AM | #4 |
Re: Alternator
30 amps is plenty for any lighting. Wipers too. Heaters may need more.
06-05-2022, 08:59 AM | #5 |
Re: Alternator
My "A" has the original 6 volt generator fitted with a solid state voltage regulator. I converted all my lights to LED's including the headlights. The headlight lamps are the more recent Logo lights with lenses. The load or power (watts) demand from LED's are considerably less than incandescent and halogen lamps. The LED's work very well and do not dim at idle with my stock 6 volt generator. I cannot see any advantage with converting the stock electrical system to any other type unless you plan on operating large power consuming devices.
06-05-2022, 09:05 AM | #6 |
Re: Alternator
I had a 6-volt alternator on my old Ford 850 tractor and had problems with it so I changed over to 12-volts with a group 25 battery and it's much more reliable now. I wired it with a generator light in the panel and is excites as soon as the engine is running. Last edited by rotorwrench; 06-05-2022 at 09:11 AM. |
07-16-2022, 05:12 PM | #7 | |
Re: Alternator
BOB What kind of mounting bracket did you used for mounting alternator? Tks |
07-16-2022, 05:37 PM | #8 |
Re: Alternator
I'm ok with my 6-volt 30 amp alternator except that with the higher than 6 volts it puts out, I lose the ahh from my ahhooga horn. I can tweek it some but then it doesn't sound right with the engine shut off. This could be a problem with the horn, I'm not sure. The horn not working right takes a lot of fun out driving.
07-16-2022, 07:46 PM | #9 |
Re: Alternator
I drove to Mebane (109 miles each way) today to visit other Model A owners. As I pulled into the turnoff for Pete's house I noticed that my ammeter was reading negative (discharge) and the volt meter read 12 volts instead of the usual 14. After some measurements it was determined that the alternator was toast. Colin drove me to the Napa dealer in his 1929 coupe and I picked up a new alternator, off the shelf. We had to change pulleys but nothing more. I would have never made it home without a new alternator. Lesson learned: Having a 12 volt alternator means you can go to Napa or any other auto parts store and pick up a new one.
I am going to fix the old one and keep it as a spare. I have fixed them before. Usually it is just new brushes but sometimes a diode can be burned out. By the way, the new ammeter showed a charge current for more than the usual time and a higher rate than usual. It took a while to change up the battery and then it went to the usual readings of zero amps and 14 volts.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 07-16-2022 at 07:54 PM. |
07-16-2022, 07:53 PM | #10 | |
Re: Alternator
I have spoken many times about our trip into remote areas - trips I wouldn't dream of doing unless I was on 12 v. A CB radio is a must and for those times when phone reception is available, you need the phone to be charged. I haven't seen any 6 volt adaptors for that.
07-17-2022, 09:17 AM | #11 | |
Re: Alternator
Seems like a potential bomb under your feet. |
07-17-2022, 09:46 AM | #12 |
Re: Alternator
The starter will rotate at higher rpm but will function on 12-volts. A person can change the fields if they want to but it will work as is.
07-17-2022, 10:41 AM | #13 |
Re: Alternator
Changing the fields amounts to changing the wiring of the fields from 2 in series and 2 in parallel to all in series. You can buy new field coils for 12 volts or re wire the old ones if they are in good shape. It requires some soldering skill and a good soldering iron. I found the best iron to use is the old style Weller ones with a trigger. They heat fast and you can control the temperature by pulsing the trigger. A good lead-tin solder with a rosin core is best. You may have to go online to get the solder as the ones in the hardware stores are for plumbing and not the 60-40 lead-tin.
A trick to get the iron poles out is to clamp the poles to the case to relieve the pressure on the screws. Do the opposite when re installing the iron poles.
07-17-2022, 08:12 PM | #14 | |
Re: Alternator
How has the topic of this thread wandered from alternator to starter motor??
