07-19-2021, 01:02 PM | #1 |
Early Y Block OHC 239 Spark Plugs
Did the early 239 Y Block have 18mm spark plugs, or, 14mm? Heard it both ways. I argue this once a week. Please, someone put this to bed. Thanks.
James |
07-19-2021, 02:36 PM | #2 |
Re: Early Y Block OHC 239 Spark Plugs
14mm. 1955 was the first year for the tapered seat 18mm. (If I'm remembering correctly)
07-19-2021, 02:39 PM | #3 |
The EBU 239 had 14 mm - the EBV 239 (most of these ended up in trucks in 55) had 18mm.
Of course, over the years people have changed out heads, blocks, and the whole gamut. I have disassembled several Y blocks that had mismatched heads.
Lancaster, California Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
07-19-2021, 03:30 PM | #4 |
Thanks, for confirming. I thought I was right, but, have couple of buddies, who didn"t believe me, so, I wanted to hear someone else say it. Thanks for your time.
James |
07-19-2021, 03:37 PM | #5 |
Thanks, for confirming. I thought I was right, but I have a couple of buddies who didn't believe me, so, I wanted to hear someone else say it.
07-19-2021, 07:31 PM | #6 |
https://www.sparkplugs.com/champion-...kel-spark-plug |
07-19-2021, 09:27 PM | #7 |
For whatever it's worth,
the '54 EBY / 256 engine I had used the metal gasket 14mm spark plugs also. . Last edited by dmsfrr; 07-19-2021 at 10:23 PM. |
07-20-2021, 04:44 AM | #8 |
i remember seeing a 55 ford 292 with big plugs on one side and small ones on the other.ran nice.
07-20-2021, 06:05 PM | #9 | ||
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
07-20-2021, 08:06 PM | #10 |
"TURBO-ACTION"?
OK... Was Champion pulling our leg? |
07-21-2021, 08:55 AM | #11 |
FORD used CHAMPION from 1955 until they bought certain parts of AUTOLITE (but they won't), wanting mostly the SPARK PLUG DIVISION.
FOMOCO - ROTUNDA - AUTOLITE - MOTORCRAFT
