07-19-2021, 12:53 PM | #1 |
12 Volt Bosch blue coil PN-00012
I am having a hard time locating this coil. Buba recomends them. Does anyone know where I can buy a couple of them. Other than E Bay ? Thanks stan
07-19-2021, 01:04 PM | #2 |
Re: 12 Volt Bosch blue coil PN-00012
https://www.amazon.com/Bosch-00012-I...s%2C196&sr=8-5
They say they have 3 left and they are discounted. |
07-19-2021, 01:24 PM | #3 |
Lots of VW/Porsche suppliers list them.
Making the simple complicated for over 30 years. |
07-19-2021, 07:37 PM | #4 |
The Bosch "Blue" coil is nominally 3 ohms, one thing I can't figure out is why Bubba doesn't recommend a coil closer to the OEM value when used with points & switched ballast. Ford used (about) 1.4 ohm coils with an external ballast resistor for many years in 12 volt systems. So for these applications, it would seem like the Bosch "Red" coil of 1.8 ohms would be the logical choice?
07-20-2021, 09:54 AM | #5 |
I am going to use the Blue Coil PN-00012 . As per Buba! I hope he replys !. Now I am concerned ! I hope Buba can make me feel better. Thanks Stan
07-20-2021, 09:57 AM | #6 |
07-20-2021, 09:58 AM | #7 |
Also with Bubas Condensers! Stan
07-20-2021, 11:04 AM | #8 |
07-20-2021, 11:23 AM | #9 | |
There were no early Fords with a 12 v,. supply. When changing over to 12 volts, this is the coil to use dump and any resistor in the circuit. |
07-20-2021, 12:35 PM | #10 |
I've been using the black 00012 same coil just oil filled instead of epoxy..
07-20-2021, 01:26 PM | #11 |
I've had good luck with the Beru 12 v. blue coil and it's half the price of the Bosch.
07-20-2021, 03:31 PM | #12 |
Tubman, You are correct, Sorry I bought them from you. As you get older you make more errors. Sorry . Stan
07-20-2021, 05:58 PM | #13 | |
A 3 ohm ignition coil could in theory have more difficult cold starts, or possibly when flooded. Ford set up their 12 volt ignitions the way the did for a reason, all cars and trucks from 1957 to 1974 basically. Many other makes and models did exactly the same thing. ' |
07-20-2021, 06:27 PM | #14 | |
I can't wait to see the finished product! |
07-20-2021, 07:46 PM | #15 | |
07-20-2021, 07:54 PM | #16 |
I have always stocked the Vertex Magneto condensors. Never seen a defective one ... .36 mfds
07-20-2021, 07:57 PM | #17 |
Yep i am hooked on the Bosch blue coil at 3.0 ohms , been buying them from amazon . I have also used the beru blue coil , a little less ohms but a good unit as well......
07-20-2021, 08:02 PM | #18 |
I've heard of Ballast resistors going bad occasionally but I don't think it's a cause for concern. Ford didn't seem to think so either (nor GM or Chrysler etc..) Remember this was THE classic points and condenser wiring circuit for millions and millions of cars and trucks, back when hollow state igntion ruled the roost.
07-20-2021, 09:48 PM | #19 |
To each his own.
07-21-2021, 08:22 AM | #20 |
A failed ballast resistor had me hitchhiking to work one morning.
Enjoy yer day. Tom Hate can't fix what it started. |
