Old 07-16-2021, 03:13 PM   #1
bonanza7369
Default windshield wipers
the wipers on my 56 fairlane are very slow. does not seem to be any leaks in the line from the fuel pump.
any ideas other than replacing motor or going electric.
bonanza7369 is offline   Reply With Quote
Old 07-16-2021, 03:50 PM   #2
KULTULZ
KULTULZ's Avatar
Cool Re: windshield wipers
Do you have a SHOP MANUAL? The easiest and quickest way to go about it is to follow the diagnostic sequence in that manual. Otherwise you are going to hear all kinds of suggestions that will have you chasing your tail.
A combination fuel pump and vacuum booster is standard equipment on cars equipped with Overdrive or Fordomatic.
SOURCE - 1957 WSM
My learned factoid of the day. I did not know that. I was under the impression that it was included with hi-trim levels or was an option.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-16-2021, 03:52 PM   #3
Dobie Gillis
Dobie Gillis's Avatar
Default Re: windshield wipers
Try this:
Here's how to lubricate the motor, which should be done three or four times a year:
1. Remove the vacuum hose at the wiper motor. Lightly hold your finger over the hose nipple on the motor and cycle the wiper blade back and forth.. Note that in one direction the motor sucks in air, and in the opposite direction, the motor expels air through the nipple. Place the wiper blade in the position such that the motor will begin to suck air at the nipple.
2. Attach a six‐inch long piece of hose to the motor nipple and hold the open end up. Using a squeeze bottle, force one teaspoonful of lubricant into the hose.
3. Cycle the wiper blade back and forth several times. Repeat the process again, adding a second teaspoonful of lubricant.
4. Start the engine and run the wiper motor. It should run well. If it does not, the wiper motor should be disassembled, cleaned, inspected and a rebuilding kit installed. It is normal for the wipers to slow down when the car is accelerated, but they should not stop altogether.
Use a light machine oil such as 3 in 1.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 07-16-2021, 04:25 PM   #4
KULTULZ
KULTULZ's Avatar
Thumbs up Re: windshield wipers
! Off To The Races !
- WHY IS IT ... -
Old 07-16-2021, 08:58 PM   #5
Daves55Sedan
Daves55Sedan's Avatar
This is an issue where beginning the investigation at the source may save some time.
If your manifold vacuum is low, you may experience slow wiper movement, even though you may have a vacuum booster on your fuel pump. After all, it is a booster.
Check intake manifold vacuum at engine idle. Should be around 19 on the guage.
If that is okay, pull the rubber hose off the vacuum wiper motor and connect vacuum guage to the hose. If the vacuum is lower, there's a crack in the rubber hose feeding the system. Or, could be vacuum booster diaphragm is cracked.
Daves55Sedan is offline   Reply With Quote
Old 07-17-2021, 08:45 PM   #6
Gene F
Gene F's Avatar
I have a tri-power and it ideas fairly high in neutral. I bet my vac is not that high.
Gene F is offline   Reply With Quote
Old 07-18-2021, 06:05 AM   #7
KULTULZ
KULTULZ's Avatar
19-20 in per FORD spec.
Valve and IGN timing are crucial to achieve it. Remember, the booster pump does not cut in until manifold vacuum drops to a certain point. It is not continuous operation.
Of course all of this info is readily available in the correct year SHOP MANUAL.
Old 07-18-2021, 11:39 AM   #8
Gene F
Gene F's Avatar
I mean manifold vac, since I have elect wipers...
