Old 07-12-2021, 03:21 AM   #21
KULTULZ
KULTULZ's Avatar
Arrow Re: Copper washers for master cylinder and power booster fittings
Originally Posted by KULTULZ View Post
Yes, you can use the gaskets from DORMAN and/or a parts jobber. The serrations are as a result of the washer being crushed when torqued, Anytime you take a banjo-fitting apart, you automatically replace the washer(s).
Let me correct myself here. The washer OD must not be larger than the actual serrated area of the machined block or the washer cannot seat properly to be crushed.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-12-2021, 07:48 AM   #22
zuburg
zuburg's Avatar
Default Re: Copper washers for master cylinder and power booster fittings
Ah, the Dorman part number I referenced earlier had too large an O.D. That may be why they did not seal. They were also a little thicker. The Ford part 2154 is barely bigger than the hole and thinner. I swear the last time I ordered them, they had the concentric rings on the flat part already. I have some more on order so will take a close look.
zuburg is offline   Reply With Quote
Old 07-12-2021, 09:54 AM   #23
KULTULZ
KULTULZ's Avatar
Unhappy Re: Copper washers for master cylinder and power booster fittings
If they are serrated, please let the board know.
FROM POST #5
Well I was able to find some Dorman washers that fit snugly over the shoulder. These had a larger O.D. than the original and were a little thicker. For anyone interested, the part number is 097-829CD, and are described as M12 • 1/2” (1.3 cm) S.O.
That was just a mistake on my part. I a$$-u-me(d) that whatever replacement you would find would have the same OD. That and I can't read and retain.
It appears you have the engine bay well detailed. A few finished photos will be nice ...
- WHY IS IT ... -
Old 07-20-2021, 06:17 PM   #24
zuburg
zuburg's Avatar
Thanks for the pointer to NAPA. I had no luck at Autozone, Advanced Auto and O’Reilly.
The part that was an exact fit from NAPA was:
Part Number: 1244
On the box of quantity 10, this was printed:
1244
1947 (10)
Copper Gaskets
Hope this helps.
