06-29-2021, 11:38 AM | #121 |
Re: New baby 1953 Merc
The Borg Warner plant on Kilgore Avenue in Muncie Indiana was where the first Ford-O-Matics were manufactured by BW. Ford built the Fairfax plant starting in 1949 for its own manufacture of the FOM/MOM transmissions. It was completed and in production by the begining of the 1951 model year. Borg Warner likely started manufacture at the Marvel Schebler/Tillotson Division plant in Decatur, Illinois in 1955.
This puts most of the early 1P type transmission manufacturing between the Ford Fairfax plant and the BW Muncie plant. |
06-30-2021, 04:27 AM | #122 | |
That explains why the only BW ID TAG I have come across were after 1954 model year. Now the question is was there a separate 1951-54 ID TAG for BW and can we find an example to duplicate.
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
06-30-2021, 09:33 AM | #123 |
My thoughts exactly. Hopefully, someone will be able to post a picture of a transmission tag (50'-53') that was built at the Muncie plant.
06-30-2021, 05:15 PM | #124 |
Stuck valve in number 6 now. PB Blaster in the spark plug hole and let sit for a day or two?
Don't want to pull the manifold if I don't have to.....tranny shifting good now after a change. |
06-30-2021, 06:06 PM | #125 |
[QUOTE=bigd1101;2031714]Stuck valve in number 6 now. PB Blaster in the spark plug hole and let sit for a day or two?
Don't want to pull the manifold if I don't have to.....tranny shifting good now after a change.[/QUOT Pulling the intake manifold if really a simple job. The hardest part is the vacuum line into the back of the carb, to get it to line up at the proper angle. It is a blind hole, as you lean over the side of the fender, with you head under the hood, while you are putting in back on. Other than that, it is all straight forward. Fingers crossed, hope the PB blaster works for you. Keep us update on the PB Blaster solution. Last edited by Merc Cruzer; 07-01-2021 at 11:29 AM. |
06-30-2021, 08:12 PM | #126 |
07-01-2021, 02:29 AM | #127 |
They would be an outside supplier/vendor to FOMOCO.
07-01-2021, 12:31 PM | #128 |
Not sure if I used the wrong stuff here. If so, I guess I'll have to drain it out. Let me know. I was sure until I read the bottom part of the bottle. I was looking at the "do not use after" model years. Then I see it says not to use where Type F is recommended. Do I need to drain this out and start over again? If so, what freaking brand DO I use??
https://www.tractorsupply.com/tsc/pr...All%20Products |
07-01-2021, 01:54 PM | #129 | |
"Do not use this product in transmission that specify Ford Type F," I am changing mine and I had to order it (Valvoline Transmission Fluid Type F) from O'Rilleys, it only took one day to get it in. https://www.oreillyauto.com/detail/c...on+fluid&pos=0 Last edited by Merc Cruzer; 07-01-2021 at 02:04 PM. |
07-01-2021, 02:31 PM | #130 | |
07-01-2021, 02:58 PM | #131 | |
Since it was up on the ramps anyway, I though it would be a good time to take off a coupe of pieces of sheet metal, and repaint them. Got a good picture of the torque convert drain plug for my records. I will clean off the back of the torque converter, while I am at it too. Might want to check the bolts, to make sure they are tight, while you are there. I did for piece of mind. Last edited by Merc Cruzer; 07-01-2021 at 03:18 PM. |
07-01-2021, 03:37 PM | #132 |
It came down to two choices for me, price might differ, depending where you buy it:
07-01-2021, 06:21 PM | #133 |
Just when I was ready to change the transmission fluid tomorrow, the gasket /filter supplier, sent me the wrong one.
I ordered picture #1 and they sent me picture #2. Reliable supplier, (ATP), so it shouldn't take long to get me the correct one. ************************************************** ********************** I guess I was wrong: Here is the original add on E-bay: https://www.ebay.com/itm/38411381192...Cclp%3A2563228 Correspondence between ATP and myself: From: [email protected] To: [email protected] Sent: 7/1/2021 6:39:46 PM Mountain Standard Time Subject: Re: blackporsche1987 sent a message about ATP Automotive Auto Transmission Filter Kit for 1952-1956 Mercury Custom pl #384113811924 My e-mail is: [email protected] I have to admit I don't understand when you say: " We are sorry it does not appear to match the kit pictured." Why don't the parts look like the ones pictured in the add? Send me the prepaid return label, and I will return the wrong parts, for a full refund, to include shipping and tax. You should really change your add to reflect what is being sent when ordering: ATP Automotive Auto Transmission Filter Kit for 1952-1956 Mercury Custom pl In a message dated 7/1/2021 6:29:14 PM Mountain Standard Time, [email protected] writes: Dear blackporsche1987, Hello, The part number ordered matches the part number sent on the box in the picture. This is ATP kit B-33. We are sorry it does not appear to match the kit pictured. We do not know the part number of the kit you would require with the more rectangular shape. We can provide a prepaid return label for a full refund upon return receipt of the new and uninstalled part. If you would like to be set up for a prepaid label please provide a personal email for us to send it to. We apologize for any inconvenience. If you have any questions or concerns please reach out. Regards, Sixity Auto Direct Customer Service Thank You, Sixity Auto Direct Customer Service:::a0S3w00001G5InCEAV::: On 2021-07-01 21:41:39, blackporsche1987 asked:I ordered: ATP Automotive Auto Transmission Filter Kit for 1952-1956 Mercury Custom pl:https://www.ebay.com/itm/384113811924 The first two pictures are what you sent me, the third picture is what I ordered. Last edited by Merc Cruzer; 07-01-2021 at 07:49 PM. |
07-01-2021, 11:02 PM | #134 | |
http://www.therepublic.com/2020/02/1...y_get_new_use/ Built in 1935, the industrial facility originally housed the V.E. Sprouse Co., an Indianapolis-based firm that made humidifiers, fans, electric motors and auto parts. It wasn’t until 1953 that the business changed its name to Vernco Corp. https://www.newspapers.com/clip/7673...y-of-building/ |
07-02-2021, 12:10 AM | #135 |
Love it
07-02-2021, 03:33 AM | #136 | |
07-02-2021, 08:23 AM | #137 | |
It seems I was wrong in recommending them. Now if you want another caveat (Fr.) thrown into the mix, their product photos are the same as another E-BAY seller showing a NOS B9AP 7A098-B FM filter. https://www.ebay.it/itm/Transmission...c/264297128980 When you expand the attachments there is descriptive text below them.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 07-02-2021 at 08:37 AM. |
07-02-2021, 08:34 AM | #138 | |
07-02-2021, 08:59 AM | #139 | |
I would guess maybe a quart will remain in the converter. |
07-02-2021, 09:11 AM | #140 | |
https://www.ebay.com/itm/15437105901...733b00e67b8533 I might just be setting myself up for failure again. Who would ever guess changing the trans fluid on the car would be such an issue. When I called O'Riellys to check on the one they had advertised, they said it was special order and I would have to pay shipping. Remember that discussion on just cleaning the screen a few post back, well it might just come to that. I checked with the guy that has the NOS screen and it doesn't have the "O" rings. Probably not an issue anyway, as they would be all dried out by now. If worse comes to worse, I could always just clean the filter/screen and use silicone for the gasket. My fingers are crossed on the new surlier, his screen name is (guaranteedtofit) Today's project, make a box, to put the box the incorrect filter and gasket came in, to send it back for a refund. They sent it in a bag with bubble wrap. |
