Old 08-02-2019, 08:53 AM   #1
katy
katy's Avatar
Default Anyone else use rims for blocks?
I've been using rims for blocks for years, nice and stable, don't have to worry about a vehicle rolling off of them, they give more room than axle stands when working under a vehicle. Sometimes I double stack them for more height, a 15" on the bottom and a 14" on top, they nest together very well. Very stable.
Old 08-02-2019, 10:45 AM   #2
Cool Hand Lurker
Cool Hand Lurker's Avatar
Default Re: Anyone else use rims for blocks?
Looks like a good idea. Do you use them for long-term storage? Do the rim edges affect the tires?
Cool Hand Lurker is offline   Reply With Quote
Old 08-02-2019, 01:00 PM   #3
burner31
burner31's Avatar
That's some old school stuff, junkyards are famous for their use
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 08-02-2019, 02:24 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, most yards use them, but I can't understand why French Lake removes the wheels and sets the cars directly on the ground, making the bottom parts all but impossible to remove, as well as rusting out all the lower parts on the antique cars.
Old 08-02-2019, 09:38 PM   #5
Cool Hand Lurker
I think the way Katy uses them with a 14" rim set inside a 15" rim is a lot safer than the junkyard method of putting one upright inside another. With Katy's method they are not likely to shift or move but the junkyard method could tip to the side.
Old 08-03-2019, 09:30 AM   #6
katy
katy's Avatar
No.
No.
I've seen them like that welded together.
FWIW, I store them in one stack,15", 14", 15", 14", etc.
Old 08-03-2019, 11:32 AM   #7
Ruth
We use a 55 gal. drum to hold 'er up.
Old 08-03-2019, 07:21 PM   #8
Cool Hand Lurker
No comment necessary.
