04-13-2018, 09:19 AM | #1 |
Do I need a new worm in the steering box?
I'm planning on rebuilding the steering box on our '31. I see that Bratton's steering box rebuild kit doesn't include the worm. What's the likelihood that I will require a new worm? Or will the original still be in good enough shape to re-use it?
Tnx, Ken
04-13-2018, 09:29 AM | #2 |
Re: Do I need a new worm in the steering box?
Katy...prolly unknown until you can examine the condition of the original.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
04-13-2018, 09:38 AM | #3 |
if the sector is worn the worm is worn. best to replace them both then you dont have to worry about it for your lifetime or your kids lifetimes.
1929 Model AA - Need long splash aprons! |
04-13-2018, 09:45 AM | #4 |
My two cents is the sector gets worn only on the two teeth, where the worm gets worn all the way around. Seen as how the lash between the two is adjusted tight in the middle and the full left / right lock is engineered to be looser, I don't think wear on the worm is important when it can be adjusted out on center by the normal procedure. I am sure opinions will vary.
04-13-2018, 09:56 AM | #5 |
Just did mine a few months back.
Best to just change it out now, you're re-building it for a reason, do it all at one time and done. Putting the worm gear on the shaft is tricky bussiness, it comes off easy with a press but going back on is a "whole" new adventure. If I would have bought the worm gear with the shaft when I got the kit I would have saved $200, alot of time, frustration and would not have a extra (bent) shaft and an extra worm gear now. If you go to press the gear on yourself you will have to mill down the shaft end a few thounsands to fit the new worm gear and you'll need a "tall" secure press, good luck there, even desiel shops don't have presses that big anymore. And if the shaft is not set perfectly in the press "BAM", in less then a second you have a bent shaft. Don't cheap out when it comes to the steering box, you'll be needing it everytime you take her out. That's my experiance...your's may differ
04-13-2018, 10:02 AM | #6 |
04-13-2018, 10:12 AM | #7 | |
Your logic seems reasonable with the exception that much of the wear of a steering gearbox comes from rotating the steering wheel less than 90° from center in either direction, -so the worm never really gets worm completely. This is the same reasoning why the steering arm balls and the pitman arm ball always wear excessively in the 3 & 9 position instead of in a complete circle. What happens when adjusting the worm when worn in the center is if the backlash is adjusted out to compensate for the wear in the center, the clearance becomes too tight (i.e.: binds) when the sector teeth reach the ends of the worm. |
04-13-2018, 10:26 AM | #8 |
I did the same thing Keith was talking about and bent the shaft. Also kind of beat up the worm gear. I wound up having to buy a new shaft with the gear already on. It's awhile ago but I think it was in the 2 hundred dollar range. And I wasted most of a saturday. Good luck, Frank
04-13-2018, 10:36 AM | #9 |
Do it right the first time.
Replace both. Now you know it is as good as it can be. |
04-13-2018, 11:32 AM | #10 |
Replace both!! I had to pull mine apart a 2nd time and replace the worm gear to remove all the slop.
04-13-2018, 08:32 PM | #11 |
Rebuilt mine this winter. Bought everything. Took the gear and shaft to a local machine/welding shop. They also service a lot of big trucks and tractors. Pressed the gear off the shaft with a 20 ton press. To put the gear back on, he kind of tapped it on the shaft with a brass hammer. Then laid a 12 inch square piece of aluminum that was 1/2 inch thick on the cement floor. Turned the shaft over, with the gear down, and slammed it in the piece of aluminum about 20 times, and it was on. He said that is how they do all the steering gears when guys are rebuilding old tractors. I had researched this for months, and planned and plotted all kinds of back up plans, and he made it look so easy.
04-13-2018, 11:48 PM | #12 |
Glad I wasn't there for that, I don't know if I could have contained myself.
Personally I drive my car a little bit faster than an old tractor. You must have Saint Henry on your shoulder.
04-14-2018, 09:07 AM | #13 |
Thanks for all the info, I'll order a rebuild kit and a worm.
I have a 20 ton press that is up on blocks w/extensions hanging on the bottom so I can put long stuff in it. I learned a long time ago to use a length of close fitting square tubing w/a heavy wall, on long pieces to keep them from bending, but I'll probably try that aluminum on the floor trick.
04-14-2018, 09:18 AM | #14 |
Chances are the bearing surfaces are pitted.
04-14-2018, 09:37 AM | #15 | |
We all love a success story.
04-14-2018, 09:43 AM | #16 | |
04-14-2018, 04:38 PM | #17 |
Katy - press the worm gear off with the press but, by all means, get Diablo A's video describing how to tap the shaft & drive the new gear on with an impact gun. I did the job this past winter. You'll need to be patient with the install but it works!
Glen M |
05-11-2018, 09:50 AM | #18 |
Well I received the rebuild kit and the worm. I notice the worm has some shallow splines in the ID. I'm assuming that this is telling me that it only goes on one way? Nothing I've read talks about that, just R&R the worm. I suspect that the worm needs to be lined up w/the keyway for the steering wheel.
Hopefully I can get started on it next week.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 05-11-2018 at 09:51 AM. Reason: Addition |
05-12-2018, 05:26 PM | #19 |
Install it VERY CAREFULLY, so's your NEW WORM doesn't up & "DIE" on you!
Bill Bungler
06-12-2018, 09:09 AM | #20 |
I finally got the steering box rebuild completed and adjusted. I used the "aluminum plate on a concrete floor" method to install the worm on the shaft, worked slicker than snot on a doorknob. The thickest aluminum I had was 1/8" and it took a beating, but it worked OK.
When I removed the worm from the shaft the gauge on the press showed less than 1 ton pressure. Now to get it all back in the truck and buttoned up.
