Old 03-02-2018, 05:10 PM   #1
john in illinois
john in illinois's Avatar
Default Trimming intake gasket to port
I have heard of this. Are the benefits worth doing it?
john in illinois is offline   Reply With Quote
Old 03-02-2018, 06:18 PM   #2
JSeery
JSeery's Avatar
Default Re: Trimming intake gasket to port
It is normally done the other way around, the port in the block is matched to the gasket. Guess it might depend on the gasket you are using, but most of the ones I have seen are fairly precise.
Old 03-02-2018, 06:22 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
If the gasket is causing an obstruction in the air flow path. Why not trim it?
Old 03-02-2018, 10:49 PM   #4
Talkwrench
Talkwrench's Avatar
If it's in the way, or port matching..
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 03-03-2018, 08:25 AM   #5
john in illinois
JS I think that is what I was thinking,matching ports to gasket. My engine rebuilder mentioned that he did that. I am putting on a new manifold ,so I will check it out.
John
Old 03-03-2018, 08:34 AM   #6
Pete F
Pete F's Avatar
John
If your putting a new manifold on I would match the gasket to the block and than match the gasket to the manifold.
If the block was ported every little bit helps
Pete F is offline   Reply With Quote
Old 03-03-2018, 02:47 PM   #7
Ol' Ron
Ol' Ron's Avatar
"Back in the day", What ever that means, they made a big bore intake gasket. I don't eel that's necessary for a street engine. However you can make your own port matching gasket by using part of the box the gasket came in and tapping it around the block ports, then comparing it to the intake manifold. This will show you the miss match, if any.
