Old 01-25-2016, 04:28 PM   #1
figment
Default Re-Blueing Spark Plug Bases
Can anyone recommend someone that still does the actual blueing on the spark plug iron bases?( not the blacking that is mostly done now. ) Thanks , Norm
figment is offline   Reply With Quote
Old 01-25-2016, 04:41 PM   #2
CarlG
CarlG's Avatar
Default Re: Re-Blueing Spark Plug Bases
Check out the various Blueing compounds available at your local gun / sports shop.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-25-2016, 05:19 PM   #3
figment
Thanks , I may have to do that. I was looking for the process called hot blueing that was the original finish on early spark plugs. It does hold up better than the cold process as I am told. I had someone in Grand Rapids Mi. some time back but he has passed away. Norm
Old 01-25-2016, 05:23 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
There are gun shops that still do hot blueing, but it cost considerably more than cold blueing. I stripped the rust off my Remington Model 41 Targetmaster and used G-96 cold blueing. It did a very nice job. I rubbed it down with ATF as soon as I rinsed off the blueing. I used my Milwaukee heat gun to preheat the gun parts before I applied the blueing.
Old 01-25-2016, 07:24 PM   #5
figment
Thanks Tom , I haven't found anyone near that has a hot tank so I will may have to go that route.
Old 01-25-2016, 09:30 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I, also, have a Remington Model 41 Targetmaster, from the '30's. In the mid 50's, I stripped it down, polished ALL the parts & blued it myself, in a HOT Commercial Blueing tank & it still looks NEW!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-26-2016, 01:34 AM   #7
mike657894
mike657894's Avatar
cold bluing will give a black appearance i like it on the guns i have done but its not blue. brownells sells hot blueing salts. but only in large expensive jugs. like 150 dollars. since plugs are small it would be an easy project. do it outside because of fumes. but since they are small and your not going for presentation gun quality blue. i would think you could send it out and have them hot blued for a pretty reasonable
price.
mike657894 is offline   Reply With Quote
Old 01-26-2016, 11:41 AM   #8
Fullraceflathead
Fullraceflathead's Avatar
I did the cold bluing on mine turned out very well. Make sure all rust is removed first if you have any.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 01-26-2016, 11:47 AM   #9
figment
Thanks for everyone's advice. Does anyone know a gunsmith in Michigan or near by that does hot blueing?
Old 01-26-2016, 12:28 PM   #10
BILL WILLIAMSON
I've done a lot of Blueing, REMEMBER, It's REALLY HOT, NOXIOUS FUMES, & if you get the salts on your skin, it BURNS & leaves like a BIRTHMARK, that lasts & lasts!
Bill W.
Old 01-26-2016, 12:57 PM   #11
Tom Wesenberg
Have you tried a Google search for "hot gun blueing" in your area?
Old 01-26-2016, 06:37 PM   #12
noboD
There are two different processes, blueing and black oxide. Contact any machine shop to get black oxide done, it's very cheap.
noboD is offline   Reply With Quote
Old 01-26-2016, 06:55 PM   #13
figment
I did a google search for gun hot bluing and found some places that do guns. I will contact some and see if they will do some spark plug bases. Thanks , Norm
