Old 03-29-2015, 06:01 PM   #1
kiwitony
kiwitony's Avatar
Default Edelbrock 500 cfm carb
Hi guys, I'm concidering one of these carbs for my pickup, any advantage/disadvange for the performer series over the thunder series, price is within a few bucks at the moment.Thanks in advance Tony.
kiwitony is offline   Reply With Quote
Old 03-29-2015, 06:33 PM   #2
36tudordeluxe
36tudordeluxe's Avatar
Default Re: Edelbrock 500 cfm carb
Am using the Edelbrock 500 but it's on a 276 cubic inch engine; think it might be a little much for a stock engine.
36tudordeluxe is offline   Reply With Quote
Old 03-29-2015, 06:37 PM   #3
Brian
Brian's Avatar
Tonys engine ain't a puny 276! 284 cubic inches built at considerable expense by a reputable builder I know...
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 03-29-2015, 06:46 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
Been running a Holley 1404 on my stock 255 Merc.
Has great adjustability and runs well.
The 1801 Thunder series is virtually the same carb. with added adjustability to the secondary's.
Considering that you will probably be running the carb on 2 barrels 99.9%
of the time the 1801 (to me) doesn't make much sense.
Old 03-29-2015, 09:29 PM   #5
Ol' Ron
Ol' Ron's Avatar
I think this is a very good carburetor, for this application. However these carbs are rich out of the box and need to be tuned #8,#11 jet sets work well. Also distributor advance curve a very important part of the equation here. Amazing the power and economy that can be found in a well tuned engine.
Old 03-30-2015, 12:48 AM   #6
kiwitony
kiwitony's Avatar
Thanks guys normally the thunder series are a lot more expensive but there are some deals out there at the moment so was just looking for some input. Ron i've noted your advice on previous posts,did you change primery jet sizes as well as the metering rods. thanks Tony. Brian just been to beachop ran great gave it a good fanging on occasion but holley carb still not right,talk to you soon.
Old 03-30-2015, 05:29 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
Can only assume (Ron, correct me if I'm wrong) both were changed.
#8= (1447 rod)
#11= (1422 jets)
Old 03-30-2015, 09:04 AM   #8
Ol' Ron
Ol' Ron's Avatar
In truth that was along time ago and my friend Richard did it along with a AF meter. The engine was a 276 with L-100 cam and his own Ign system. Not sure what he settled on, my present 280 has a 2GC With 52 jets, but I think it' still a little lean. I'b buy the tune up kit with the new carb. Also just put one on a 302 Ford, not sure what we ended up with.
Just to make things clear, I don't do much of this work any more, due to my eyesight. So I just sit back and take all the credit.
Old 03-30-2015, 01:06 PM   #9
GreenMonster48
GreenMonster48's Avatar
I have one on my Flathead, but I haven't logged too many miles on it. As others have said, it does run very rich out of the box. I just ordered the kit for it which includes jets and metering rods.
GreenMonster48 is offline   Reply With Quote
Thread Tools
Display Modes
