Old 10-06-2020, 03:52 PM   #1
55blacktie
Default Powermaster PowerGen
Is anyone using Powermaster's PowerGen? Recommendations?
55blacktie is offline   Reply With Quote
Old 10-07-2020, 08:20 AM   #2
Ford blue blood
Ford blue blood's Avatar
Default Re: Powermaster PowerGen
Ford 2G and 3G. The "fire issue" with 2G is corrected with the new after market wiring/connector available. Put out great voltage at idle to run A/C and a cooling fan if used.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 10-07-2020, 08:41 AM   #3
51504bat
51504bat's Avatar
Could you provide a bit more info on the fire issue? I'm going to use a 3G on the 302/AOD combo that's going in my Ranch Wagon. Thanks.
51504bat is online now   Reply With Quote
Old 10-07-2020, 01:37 PM   #4
55blacktie
Please explain "2G" and "3G." Thanks.
Old 10-07-2020, 07:32 PM   #5
paul2748
paul2748's Avatar
I put a 2G on a 64 Fairlane and had no problems with it.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-07-2020, 07:33 PM   #6
paul2748
paul2748's Avatar
These are different models of alternators used on Fords. I don't know the differences, but I think one of them is output. Try Google for an explanation of the different models
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-08-2020, 09:20 AM   #7
Ford blue blood
2G was used in 80s/90s Taurus and some other models. They were the first effort to replace the low out first generation alternators Ford used. The wire harness was "cheaped" and under the heavy load of the many gadgets it would burn the harness at the alternator. Ford did a TSB to correct the issue. Nice part is they bolt in where the 1G sat, have an internal regulator and put out good at idle power. They are in the 125 amp range. The upgraded harness for the 2G is readily available.
The 3G is the latest and best, higher output, internal regulator but is physically larger then the 1G and 2G. Care must be taken with sourcing. There are a few models that have the standard 1G mounting. Do a look on Rock Auto, they have good pictures of the alternators.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
Old 10-08-2020, 10:07 AM   #8
Ford blue blood
A quick tutorial on Ford alternators. I found the 3G for my Ranchero on Rock Auto for much less then the power master. The pulley will swap to a single/dual groove no sweat.
http://www.mustangandfords.com/how-t...rd-alternators
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
Old 10-08-2020, 01:30 PM   #9
55blacktie
Blue Blood, thanks for the attachment.
Old 01-03-2021, 06:36 PM   #10
cokefirst
I use the PowerGen alternator that looks like a generator in my old generator equipped cars. They are expensive but I am very happy with the performance and I like the fact that the unit looks period correct. If you are one of those that doesn't care about that, then you can put on a later model alternator for much less money.
cokefirst is offline   Reply With Quote
Old 01-25-2021, 07:55 PM   #11
1941Pony
If you’re running a sbf, a 3g is a great upgrade. I went from a power master that lasted a few years to a 3g. You’ll need to upgrade your charge wire though if running high amps. It is bigger too, I had to modify my brackets a little to make it fit. I also went with a slightly smaller pulley to help charge at idle so my lights wouldn’t dim while idling.
1941Pony is offline   Reply With Quote
