09-18-2017, 10:36 AM | #1 |
1936, Std vs Deluxe
I know it has been discussed or at least mentioned several times inthe past, But I am not able to find it.. So,, What are the differences between the two.. Not that it will make much difference, I like them all, just don't know the visible differences
09-18-2017, 01:41 PM | #2 |
Re: 1936, Std vs Deluxe
Trim mostly, two tail lights, nicer interior, badging, trying to do this from memory. See if you can get a copy of the Early Ford V8 book on 35/36 Fords, lots of good info.
09-18-2017, 03:25 PM | #3 |
They weren't a lot different like they were later in 1938. One tail light. One windshield wiper. A little difference in interior color & furnishing. The three window coupe was a Deluxe only body and maybe the convertibles too. The book isn't too expensive. I'd like to get a full set of the books some day. You can never have too much information.
09-18-2017, 04:14 PM | #4 |
Deluxe had chromed windshield frame, Standard was painted. Same for the grill.
Lots of small differences, if you're building a 'show car', insignifigant if you have a 'driver'. |
09-18-2017, 04:18 PM | #5 |
Chrome windshield surround.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
09-18-2017, 04:41 PM | #6 |
09-18-2017, 05:47 PM | #7 |
If your trying to do a quick ID remember it was very simple to change parts between a deluxe and a standard over the years and often done. So don't depend on just a few items, it's the whole package.
09-18-2017, 05:54 PM | #8 |
Standard had a cigar lighter but no ash-tray. Also I think the round louvers in front of the horns were chrome on the deluxe, painted on the standard. Standard had one horn.
Doug. |
09-18-2017, 06:10 PM | #9 |
the speedo trip odometer for deluxe has 4 nos.while the standard had 3
09-18-2017, 06:53 PM | #10 |
For sure true for '35, not sure for '36.
Edit to add: My '36 Phaeton is the only '36 I've known and all of 'em were Deluxe, so, two horns.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 09-18-2017 at 10:01 PM. |
09-18-2017, 08:38 PM | #11 |
Thanks,, Looking at a survivor .. Most of what has been mentioned pretty sure it's a Standard, with possibly a couple upgrades
09-19-2017, 12:32 AM | #12 |
36 std had 3.5" wide rims.
09-19-2017, 09:18 AM | #13 |
and what is the Deluxe?
09-19-2017, 10:22 AM | #14 |
09-20-2017, 05:00 PM | #15 |
I believe only the later 1937-40 V-8 60 HP cars had 3.5 inch wide rims. Late 36 deluxe had wood grained dashes. All 36 deluxes had water temp and oil pressure gages.
09-21-2017, 12:38 AM | #16 |
With all due respect the 36 std had 3.5" wide rims.My 36 std coupe had all 4 on it + the spare.I believe it is noted in the 35-36 Ford V8 Club book.
