Old 08-06-2012, 03:19 PM   #1
james.heider
james.heider's Avatar
Default 36 cabriolet window riser gear
Does anyone know what size gear is used for the window crank on a 36 cabriolet window riser? Is it a 6 tooth, 10 tooth, and is it a special part? It is not listed in any catalog.
james.heider is offline   Reply With Quote
Old 08-06-2012, 05:26 PM   #2
Dec211975
Default Re: 36 cabriolet window riser gear
I do not know what gears it takes, I ordered window regulator gears for a 1939 pickup, Midwest Early Ford sent me a B-48106-RK regulator gear supposedly fits 1932-1936 6 tooth, that did not fit properly and they told me that was the only one available, I than ordered from Mac's a WRK-48105-C regulator gear kit that there catalog says fits 35-39 and 35-47 pickup that was further off that the one I got from Midwest Early Ford. I did order a window regulator repair kit off of e-bay NOS made by Champ-Items Inc of Saint Louis and it looks like that one would work but my Tin retainer that secures the Gear is worn badly and that doesn’t not come with the gear. I talked to Little Dearborn in Saint Paul and they said they quit selling the gears made by Vintique because they would bind and they would have to refund the customer. I ended up ordering new regulators from Bob Drake and they look to be a perfect copy of the originals (I have not installed yet). When I have time I was going to draw up the replacement gears on Auto Cad and publish the drawings on the Ford Barn (probably be a winter project).
Regards,
Brian
Dec211975 is offline   Reply With Quote
Old 08-07-2012, 07:27 AM   #3
james.heider
Brian,
Thanks for the reply.
Old 08-07-2012, 10:53 AM   #4
blucar
blucar's Avatar
I can tell you from first hand experiences... The window operators, tracts, guides etc. are completely different from the closed cars/trucks..
The heavy metal frames around the windows on the convertibles, and the fact that they do not have the upper closed door frame to support the window, is what most likely makes a difference..
I just learned recently that Drake has parts for the early convertible window assembly's..
Bill.... 36 5 win cpe
Old 09-07-2017, 12:29 AM   #5
aandkt
My 36 cabriolet has 12 teeth- anyone know where to get that one?
Thanks
aandkt is offline   Reply With Quote
Old 09-07-2017, 07:56 PM   #6
johnny
suggest getting a good welder to weld on a new tooth and then file it to size
johnny is offline   Reply With Quote
Old 10-15-2017, 08:37 PM   #7
materguru
i have a 32 cab. i will try to take pic of and show as well as count and reply post haste
can you give me a pic of the piece that attaches to the windshield frame and faces the door window. it hold the rubber that helps seal when rolled up and closed.
thanks
Don Turner
materguru is offline   Reply With Quote
Old 10-15-2017, 08:42 PM   #8
johnny
connect with regulator roy 609 828 8537
Old 12-16-2017, 10:01 PM   #9
aandkt
James- I don't know what happened to the elaborate story I just wrote but -Once again- I found that Snyders at(330) 549-5313 -has a Model A 12 tooth gear..I put it in my 36 Cabriolet Regulator At first it was a bit tight but it worked in. That worked fine outside the car but I still have problems. See what they have for Model A, Measure your needs, Call them they are very cooperative.
Which side of the car are you having problems with? I may go Electric.
Old 09-29-2020, 03:58 PM   #10
aandkt
Did you try my advice And did it work for you?
