Old 09-13-2020, 01:58 PM   #1
Blastfromthepast
Default 1936 lift points for 2 post lift
Does anyone know the correct lift points for a 1936 Cabriolet.
I want to lift it on a 2 post Rotary Lift.
The chassis is not straight and I just don’t trust lifting it.
I had several problems trying and it just don’t look right.
It’s sturdy but I’m afraid it’s going to slip off the arms of the lift.
I have seen it happen to other guys and it’s a real mess.
Especially if it’s a finished car.
I think I should change to a 4 post lift.
Any suggestions.
Blastfromthepast is offline   Reply With Quote
Old 09-13-2020, 04:37 PM   #2
flatford8
flatford8's Avatar
Default Re: 1936 lift points for 2 post lift
You could make some ramps out wide channel iron and adaptors to hold them to your lift arms. Set them up for your cars track width and a little linger than the wheel base. A friend did this to his two post so he could lift his Model A’s.
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 09-13-2020, 05:40 PM   #3
dave collette
dave collette's Avatar
Hi I lift these old fords two or three times every day with absolutely no problems. Been doing it for over twenty years. these cars have a strong frame. Had my 1935 roadster up on it today. I think you are worrying about nothing
dave collette is offline   Reply With Quote
Old 09-13-2020, 06:58 PM   #4
alanwoodieman
after working on/under both four post and two post, I would rather use a 4 post on the old cars with a rolling lift table . two post I see the need for an extra stiff knee/post and yes I have seen a two post lift bend the frame on a restored 40 sedan--It was mine!
alanwoodieman is offline   Reply With Quote
Old 09-14-2020, 09:54 AM   #5
rockfla
rockfla's Avatar
I've lifted m 39 Merc where the side rails meet the "X" frame junction points with no apparent problems.
Old 09-14-2020, 10:11 AM   #6
corvette8n
corvette8n's Avatar
https://www.fordbarn.com/forum/showthread.php?t=256084
See my post on quick jacks, my garage ceiling is about 7ft. I did notice that the passenger door doesn’t close as nice on the quick jacks. I assume the frame is flexing or the weight of the front end is pulling door out of alignment a little.
Old 09-14-2020, 06:26 PM   #7
mrtexas
mrtexas's Avatar
IMHO I was surprised with how light and flimsy the frame on my 36 wagon was when I took it off for paint.
I did however make 4-6 inch tall extensions for the arms to get them up high enough to clear the body when lifted. Other problem was 2 post needed to have posts closer in for flatheads and farther out for modern cars.
I got rid of my 2 post lift after I got tired of bending down to place the arms.
If I had to do it again I'd put a 2 x 12 across each arm pair front and back bolted to the hand on the arm to spread out load on the frame
Have 2 bendpak 4 post lifts and one bendpak parking lift. Used to have maxjax 2 post
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
