Old 09-02-2020, 05:00 PM   #1
wahoo54
Default Fuse Block & Coil Resistor for 38 Ford
Anybody know where I can get a replacement Fuse Block & Coil Resistor for a 38 ford?
wahoo54 is offline   Reply With Quote
Old 09-02-2020, 05:20 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Fuse Block & Coil Resistor for 38 Ford
https://www.ebay.com/itm/1933-1938-F...-/184189084448
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 09-02-2020, 07:50 PM   #3
JSeery
JSeery's Avatar
That might work, but I have never seen one like it. Should look more like this. You can get them as reproductions, but most of them have junk ballast resistors.
Old 09-02-2020, 07:55 PM   #4
Bill OH
I used the later circuit breaker and resistor on my 38 Ford - fuses are not appealing for use on headlights
Bill OH is offline   Reply With Quote
Old 09-02-2020, 08:39 PM   #5
JSeery
JSeery's Avatar
Agree with Bill, if you are not going for 100% original I would use the later circuit breaker panel. This one actually has two circuit breakers inside the cover. The second panel has only one circuit breaker, think it was 1940 only. Starting in 1941 Ford used the two circuit breaker panel.
Old 09-02-2020, 09:01 PM   #6
wahoo54
Thanks Gentlemen! I'll look into the later circuit breaker panel.
Old 09-02-2020, 09:28 PM   #7
JSeery
JSeery's Avatar
Just be sure you get an original ballast resistor if at all possible.
Old 09-27-2020, 05:43 PM   #8
wahoo54
JSeery Thanks. Any idea where?
Old 09-27-2020, 05:48 PM   #9
JSeery
JSeery's Avatar
No, but I would check with the guys that sell NOS and see what they have or where they suggest you might look.
barnfind08 is one & Michael at third Generation is another. Barnfind08 you can PM with the question on a part and Michael it is best to call 844-317-5988
Old 09-27-2020, 08:25 PM   #10
wahoo54
JSeery I found one on ebay that's NOS. Ordered it before I saw your reply. Thanks for the info. It's a 33 to 40 single circuit breaker and ballast resistor.
Old 09-27-2020, 08:48 PM   #11
JSeery
JSeery's Avatar
LOL, Ford didn't start using them until 1940. But they would work on earlier years, just only correct for 40.
Old 09-27-2020, 09:36 PM   #12
wahoo54
Ha! That's what the ad said so I guess it would. Hope it works....
Old 09-27-2020, 11:13 PM   #13
JSeery
JSeery's Avatar
Should work fine.
