Old 08-30-2020, 07:31 PM   #1
DMMuir
Default Trunk Operation?
How were these designed to work. I disassembled and cleaned up the latch, it seems to be operational now but I have a question if it's actually working properly.
It's locked. It will open with the key, but remove the key and close it and it's locked again.
Is that normal?
Edited to add that it's a 40 Tudor Deluxe
DMMuir is offline   Reply With Quote
Old 08-30-2020, 08:13 PM   #2
paul2748
paul2748's Avatar
Default Re: Trunk Operation?
Are we supposed to guess what car you are asking about?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-30-2020, 08:52 PM   #3
Phil Gillespie
Phil Gillespie's Avatar
Is that normal?
For my car it is not. BTW its a 39 Standard Coupe.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 08-30-2020, 09:04 PM   #4
meric42
meric42's Avatar
For '41 - '48 cars I have found two different locks. One will only let you remove the key when the handle is locked and the other will release the key in either locked of unlocked position.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 08-30-2020, 09:20 PM   #5
Lawson Cox
Lawson Cox's Avatar
Phil NZ
Man, am I relieved. At first, I thought this was some sort of surgery on an elephant's proboscis. LOL
Old 08-30-2020, 10:11 PM   #6
DMMuir
That seems to be what my 40 is doing. Only released the key when the handle is locked.
Old 08-31-2020, 08:04 AM   #7
Kube
Kube's Avatar
Is that normal?
That is normal operation.
Old 08-31-2020, 09:44 AM   #8
FlatHeadCoupe
FlatHeadCoupe's Avatar
The ‘40 trunk lock cylinder (Hurd version) can be modified to be able to remove key in locked or un-locked position. I usually keep one in stock , but can modify existing if OEM Hurd.
Regards, FlatHeadCoupe
FlatHeadCoupe is offline   Reply With Quote
Old 08-31-2020, 09:55 AM   #9
deuce_roadster
deuce_roadster's Avatar
If I am using the trunk in my 40 coupe, I leave the key in the lock. Then everyone tells me I forgot the key in the trunk!
Old 08-31-2020, 03:48 PM   #10
40cpe
40cpe's Avatar
I ground the head of the key to my '40 trunk so it would fit under the cylinder cover when closed.
40cpe is offline   Reply With Quote
Old 09-01-2020, 04:35 PM   #11
slowforty
slowforty's Avatar
I put a new weather strip on my 40 Tudor. It is thicker than the old dried out one,which makes getting the trunk open interesting. you have to push on the trunk under the handle to get it open
slowforty is offline   Reply With Quote
Old 09-02-2020, 09:49 AM   #12
TJ
TJ's Avatar
Your striker should be adjustable and that should solve the problem.
