Old 08-05-2020, 08:32 AM   #1
melisahe
melisahe's Avatar
Default 49 Ford front glass
Looking for any tips on installing the two piece windshield that has the stainless trim. It looks very difficult! Thanks in advance. Mike
melisahe is offline   Reply With Quote
Old 08-05-2020, 11:25 AM   #2
mrtexas
mrtexas's Avatar
Default Re: 49 Ford front glass
Not hard. Install rubber on glass with string to pull and final install of rubber. Stainless trim goes on after install of glass.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 08-05-2020, 12:25 PM   #3
tubman
tubman's Avatar
I think "mrtexas" is right. I did this in 1959 to my '51 and the only thing I remember was that it was easier than I thought it would be. The ones I usually remember are the ones that really fought me.
Old 08-07-2020, 08:41 AM   #4
Frank Miller
Frank Miller's Avatar
I put the trim on before and it was not easy. I thenk there are two kinds of trim and mine was the single lip. You will need two people to set the windshield in the opening and maintain the angle or the trim slips out.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 08-08-2020, 06:45 AM   #5
38coop
When i put the windshield in my 49 , instructions said to put the stainless trim in first. I had two helpers and it was still a pain. We used masking tape to hold everything in place until we were ready to install it. Just make sure you have a couple of helpers.
38coop is offline   Reply With Quote
Old 08-08-2020, 08:38 AM   #6
melisahe
melisahe's Avatar
Thanks Guys, Will try tomorrow and let ya'll know how it went.
Old 08-08-2020, 10:05 PM   #7
fordor41
fordor41's Avatar
we did our '41. installed gasket on the glass, installed with me on the inside pushing and someone on outside pulling the string SLOWLY. soap the gasket and rope. after installation make sure stainless is squeeky clean. I put a coat of grease on the flange that fits into the gasket. I believe I started at the top corner, worked down and pushed it into the rubber, then across top and bottom. getting the glass thru the pass side into place was a challenge. . get d.s fully against the A pillar and keep pushing it to the drivers side . it will fit but was a job.
fordor41 is offline   Reply With Quote
Old 08-09-2020, 03:41 PM   #8
melisahe
melisahe's Avatar
Installed the windshield this morning. installed the gasket and stainless trim before installing the windshield, used masking tape to hold everything together. Mixed dawn and water in a spray bottle and sprayed liberally. Had two people on the outside pushing and holding everything in place. Me inside pulling the cord. Wasn't easy but got it in. Have one corner of stainless that popped out of the grove. That corner doesn't want to stay in but I haven't given up yet. Thanks to all for the advice. Mike
Old 08-16-2020, 09:21 AM   #9
philipswanson
Find yourself an old glass guy and save the headache!
philipswanson is offline   Reply With Quote
