02-29-2020, 04:03 PM | #1 |
Exhaust fumes
I have no leaks. On occasion on a slight downhill I can smell exhaust fumes. What could be the problem?
02-29-2020, 04:14 PM | #2 |
Re: Exhaust fumes
Most likely, blowby coming out the oil fill tube. It finds its way in through gaps in the floorboards or around the steering column. Pretty common, especially if your motor has a lot of time on it.
02-29-2020, 04:21 PM | #3 |
Re: Exhaust fumes
Hi , Sounds like Hydro carbon blow by from your breather cap. A lot of folks put a special cap on that vents it under the cab. Berts catalog pg 31 part # A6764
Keep Them on the road. Dan |
02-29-2020, 05:16 PM | #4 |
Re: Exhaust fumes
Blowby is caused by exhaust gasses getting past the rings and is worst when the engine is under load (foot down on the accelerator). On a downhill run, wouldn't his foot be OFF the accelerator and the motor slowing the car? That would mean VERY little blowby, if any on even a very worn motor. I'd be looking elsewhere.
I've seen tail pipes extended in an effort to keep exhaust gasses out. I don't think it achieves anything but I've seen it done.
03-02-2020, 06:16 PM | #5 |
Re: Exhaust fumes
I'll have to check it out more when the weather gets nice. Motor was supposed to have been rebuilt before I bought last year. I did put steel wool in the cap last summer because of some (very little) oil being blown out occasionally. i guess a compression test is in order first.
03-02-2020, 06:29 PM | #6 | |
Re: Exhaust fumes
The Master Cylinder Enjoying life at the beach in SoCal... |
03-02-2020, 09:34 PM | #7 |
Re: Exhaust fumes
That steel wool would be outa there so fast if it were mine.
03-03-2020, 06:57 AM | #8 |
Re: Exhaust fumes
other than the breather cap from Berts, what else can be done to stop the oil from entering the engine compartment?
03-03-2020, 10:48 AM | #9 |
Re: Exhaust fumes
deleted info, info same as above post with Snyders as a vendor
03-03-2020, 10:57 AM | #10 |
Re: Exhaust fumes
What Closed Cab PU said. Works as a draft tube to suck the BAD stuff out...
03-03-2020, 12:43 PM | #11 |
Re: Exhaust fumes
Any chance you have an exhaust leak? Sometimes the Exhaust Manifold/Muffler connection will leak slightly,. The leak can be so small you may not notice any increased noise. Look at the connection and see if visually there is any soot or exhaust markings. Also take the fan belt loose and blow some smoke at it to see if you can see a leak.
